Rotary shifter possible
Vakatack
Eric
New Jersey
2023 F-150 Lightning - Platinum
What happened to the break controller? Did it get left in the cavity behind the shifter?
Inquiring minds want to know!
Thanks
Yeah you can see it in the second picture of the hole in the dash. It’s just sitting back there. I never ever use it otherwise I would have found another place for it. It’s pretty small so I think it would be easy to put it somewhere else
Grencola
G
Kelowna BC Canada
f150 lightning xlt 312A standard range
Tile Setter
I bet it could also fit nicely in the side tray, where I circled in yellow 😎
Ford F-150 Lightning Rotary shifter possible Screenshot_20250409_045913_Facebook
windydrew
Kansas
23 Lightning Lariat ER
Solar Installer/Electrician
Why don't you just cut the wires on the new shifter and extend them instead of makeshift extension harness? The new shifter is cheap.
mr.Magoo
2022 Lariat ER, AMB
The new shifter doesn't come with a harness/connector.
Cutting the existing harness is probably a guaranteed way of voiding your warranty and most Lightnings are still under factory warranty.
windydrew
Kansas
Sorry, was a long day yesterday. Duh
Need to look into this more as I want my explorer rotary where my trailer controller is as well (pull trailers all the time but never use the brakes as I find the regen is plenty). I want at least 1 more cup holder since I usually have a water cup and an energy drink. Been rolling with an open console for a month now since I love the extra space and not having the shifter in my way all the time.
mr.Magoo
2022 Lariat ER, AMB
There's this as well...
https://www.f150lightningforum.com/...ion-w-3d-printed-rotary-shifter-holder.25541/
I'm working on a different version that puts the shifter at the front of that compartment instead of the rear, the harness is long enough if you undo a clip.
The back area is much deeper than the front, so one could make a slightly bigger (4" seems doable) and deeper cup holder compared to the front space.
windydrew
Kansas
That's actually where I keep it right now. I went ahead and ordered the ford tray part since it was $25. I'm thinking about just printing a part that fits in there so the shifter can go in front and will hold a 40oz water bottle or whatever in the back.
Hayden.white33
Hayden
United States
2022 F-150 Lightning
Has anyone tried the dial from a Bronco or Maverick? I've read that the Mach-E doesn't work well for some reason.
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
Dash mount is nice, but I found these videos and Etsy link for console mounting the rotary shifter that seems a bit easier - no harness extension.
2021-2024 F150 / F150 Lightning ( EV / ICE ) Center Console Trim Removal and Disassembly
(22) Replacing The Stupid F150 Lightning Shifter With A Rotary Shifter To Enable Work Surface Anytime! - YouTube
2021-2024 F150 **lightning** Stick to Rotary Shift Conversion Mount / Cubby (drop-in Replacement) - Etsy - Click the learn more link for a longer description.
I just ordered my insert and will be looking for a shifter button - but they have gone up in price on Ebay.
