90% Charge shows 139 mile Range
Old Aviator
Larry
WPB, FL
Consultant
Monday evening I drove truck on 240 mile trip. 100% charge on departure. On arrival truck showed 50 mile range remaining and I think it was 15-17%. Parked overnight and then dove it less than 10 miles next day. Range was showing about 20 miles (yes 30 disappeared) but after I drove approx 10 miles but it showed 17 remaining when I parked it and charged to overnight. Charge time was 10-11 hours to 90%.
The problem is range showed 139 miles at 90%. I thought driving it would correct but I reset the mileage computation on the charge screen. Made several short trips but so far its showing just above 130 miles and 87%.
Any clue as to what is going on?
Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost 2023 F150 Lightning Lariat
Bad modules. Go to dealer.
Towed a trailer...
Phantom trailer attached condition, check the trailer menu select no trailer attached.
Nolander
Scott
2023 F-150 Lightning Lariat Extended
The Weatherman
South Central KY
What Taxmanhog said.
HammoJ
2025 F-150 Lightning Flash
Here's another thought. Doesn't it also use the most recent miles/kWh to calculate projected miles from existing charge status. Possibly after your 10-mile trip the miles/kWh was around only 1 or less. Starting your next trip, that was the reference.
