2021 F-150 Payload Stickers
jordandev
Jordan
2021 F150 XLT 302A (on order...)
EatDirtFartDust
Josh
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
Just got mine in: xlt 3.5 eco Screw 4x4 max tow hdpp 6.5 bed 301A tow mirrors moonroof
How does that thing ride with 48psi in the tires?
Good to see I don’t have to buy full d-range tires if I’m going to push close to my max payload.
Rod507
Georgia
2021 Ford F150 XLT Powerboost
heavy duty payload package
I’d be interested to see the full spec sheet. I have max tow, moonroof, XLT on mine as well but about 1,000 lbs payload less than this.
jordandev
Jordan
I’ve got max tow, moonroof, XLT and am at 1691.
HDPP adds like 600-800 normally depending so pretty normal ??‍♂
UGADawg96
JAX, FL
302A 157 PB
2021 XLT Sport Supercrew 3.5EB 4x4 short bed.
10-speed, 3.55 locker
Max tow Package.
Came with 275/65/18 tires but I swapped them for Ford 275/60/18 wheels. Does this affect payload?
Payload = GVWR - curb weight
Tires are unsprung weight. The change is minimal. The only way to know for sure is to get a weight of the truck after the change.
kcgwhiz
Kendall
2021 F150/ 3.5 eco/ Screw/ Max tow/HDPP
Dept of Homeland Security
It rides smoother than I anticipated, it is a bit stiffer as to be expected but having driven it for a few weeks now I can honestly say it quite comfortable to drive and ride in. Haven't put it a load on it yet however.
va
2021 F150 XLT (HDPP+MTTP)
Just got my HDPP with just about every option I could get...
Ford F-150 Lightning 2021 F-150 Payload Stickers 20211114_201135464_iOS
Ford F-150 Lightning 2021 F-150 Payload Stickers WindowStickerOptions
Ford F-150 Lightning 2021 F-150 Payload Stickers doorsticker
JohnnyBoy
Arizona
www.youtube.com
'22 F150 Hybrid Lariat on order
chef
I ordered a '22 Hybrid Lariat but didn't see a HDPP option. Is it only available with certain engines?
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Very limited in what you can get the HDPP with. It's 301A or lower, and I know there are a few other restrictions with it as well.
PeanutGallery
Blake
Birmingham, AL
2021 F150 Lariat, 2019 Honda Civic Si
Architect
Just got mine today—for a fairly well-equipped truck, I’m very pleased with its payload rating. I didn’t want to give up many luxuries but still wanted a respectable payload capacity, and while I’m nowhere near a lot of you, I’m happy with where I ended up.
Truck is a Lariat 502A SuperCrew 4wd FX4 3.5EB with pano roof, max tow, 145” WB, and a few other small options—but no power tailgate, no power running boards, no spray-in bedliner, no 2kw outlet…
Ford F-150 Lightning 2021 F-150 Payload Stickers CEF4D3C5-DED1-42B5-9013-63C06C8658F6
Ford F-150 Lightning 2021 F-150 Payload Stickers 17C43312-EE83-42A1-B174-484F8A198455
coloradobrandon
Denver, Colorado
F-150 Lariat 4x4 3.5 PowerBoost
Looking to order a Lariat EB 3.5 4x4 SuperCrew. Really wanted a PB but the payload just doesn't seem to be there for my needs.
Has anyone been able to identify the difference in payload capacity, if any, of the Tow Package vs Max Tow Package? After reviewing all of the stickers it appears the tow package may increase payload due to the lighter axle...?
Twg1
Tim
SamandLily1
2006 F150 Screw, 2019 Camaro ZLE
The max tow does seem to reduce payload but impact varies depending on the spec. Ex: the Powerboost already has the 3/4 float axle, so really only adds the larger rear brakes. I think its a ~20lb-50lb hit from what I can tell in this thread depending on spec.
I can’t wrap my brain around a beefier setup with better brakes having LESS capability, so I added it despite the weight penalty.
Danoh1
2021 3.5L max tow
Pilot
Max tow long bed XLT crew cab. Beats a base f250 for towing and cargo capacity.
Ford F-150 Lightning 2021 F-150 Payload Stickers 20211125_094127
Ford F-150 Lightning 2021 F-150 Payload Stickers 20211125_094134
Valleyrider
Fresno, CA
2021 F150
I think I have the lowest payload I’ve seen in this thread. It’s a little sad when my wife’s suv has a higher payload than my new truck.
Ford F-150 Lightning 2021 F-150 Payload Stickers 9FDF6E26-9873-4DD3-BFD1-24A7EE3AA688
