2022 Platinum 22" replacement tires needed - which one would you choose?
Kohlblooded
Gordon
Santa fe
2023 ford f150 lightning platinum ev
I’ve still got quite a few miles left on my 22 Platinum’s original tires but have been really leaning towards getting these when it’s time to replace
https://www.discounttire.com/buy-tires/bfgoodrich-all-terrain-t-a-ko3#treadwell-data
I’ve had no issues with the grabbers and do have concerns with an increase in noise and slight reduction in range so have also been considering just getting another set of them instead of changing anything.
I've been pretty happy with the BFG K03’s. They are fairly quiet for an all-terrain tire.
Jseis
SW Wa
After wearing the Hankook’s out in 40K I’m happy with the Defenders. After nearly 10K, they are as quiet and as efficient as the Hankook’s.
ericpullen
ericpullen
Eric
Louisville, KY
Just to close the loop on this one, I got the Michelin Defender LTX M/S2 (275/50R22) and holy cow what a difference they have made. Smooth ride and the vibration is completely gone. Now it makes me wonder if I had a bad General tire since I got the truck.
If you have a Platinum and don’t want the full off road tire, I’m very happy with the Michelin so far!
Kohlblooded
Gordon
Santa fe
Good to know for next time. Thank you
Andrewbens
Modesto
Lightning
Mechanic
General tires are cheap. LTX make everything else feel like crap.
SmoothJ
New Jersey
2022 F150 Lightning
I noticed there are two with tirerack, so which ones did you get? Looks like the main difference is the load rating.
Ford F-150 Lightning 2022 Platinum 22" replacement tires needed - which one would you choose? Screenshot 2025-08-15 082846
Andrewbens
Modesto
Lightning
Mechanic
The bottom one is a higher load tire which is heavier which isn’t needed the top one is correct. I try to stick to Costco website because they only install the correct load tires.
Ford F-150 Lightning 2022 Platinum 22" replacement tires needed - which one would you choose? IMG_2273
Ford F-150 Lightning 2022 Platinum 22" replacement tires needed - which one would you choose? IMG_2272
Is there a difference in noise?
ericpullen
ericpullen
Eric
Louisville, KY
No, they are the same or maybe even a little quieter.
For those asking, here is the sidewall of mine for comparison:
Ford F-150 Lightning 2022 Platinum 22" replacement tires needed - which one would you choose? IMG_0489
Ford F-150 Lightning 2022 Platinum 22" replacement tires needed - which one would you choose? IMG_0490
