2750 LBS in Bed?
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
It is! My 24 Flash is 1875. The max tow and pro power must be lowering that or something because our trucks have similar equipment otherwise.
Maybe not. I have the 123 KW battery, manual tailgate with no step, no spare, no desk, no rear cupholders etc. It's a bit of a weird duck, but it was a fair price and love at first drive. It does have the tow pkg if that makes a difference.
Henry Ford
I've overloaded my truck for short trips. Best practices is to air up the tires and drive slow. You won't bend anything and power isn't an issue. Handling and braking is compromised.
If I'd have had a trailer I wouldn't have overloaded the bed.
mq019
2023 F150 Lightning Lariat ER
You're not going to hurt anything on the truck by overloading a few hundred pounds.
Your braking will be the biggest thing - longer stopping distances. Handling will also be sketchy if you take a corner too fast though probably not too bad since that stuff is pretty dense and shouldn't be a high stack and drastically effect your COG.
Watch your tires - you're running right up against their weight rating (if stock tires) but if aired correctly near their max pressure, I'd bet on them being just fine.
Short runs I've done many many times (I once ran a yard of gravel in the bed of a 1500 pickup; that was.....interesting) - 50 miles is a bit far, but given the right circumstances, and only a few hundred lbs. over, I'd do it.
People have been overloading pickups since the dawn of time (or at least since pickups were created) - keep i mind that even the "MAX" rating from the manufacturer has some cushion; things aren't going to magically fail when you exceed it by 100 lbs. or anything like that.
Your biggest problem with these trucks may be forgetting that the load is there - I've noticed when pulling my trailer with a tractor on it close to 8k lbs. that with so much power available, its easy to forget all of the weight back there! (until it comes time to stop!) :)
21st Century Truck
Martin
^^ This ^^
Maineiac12
Iowa
Shoot! I forgot the 25 Flash has a smaller battery and stripped out some features.
ntcarson
Neil
SE VA
22 Lightning
Angry Home Depot guy left "a few extra bags" of concrete on the pallet he loaded in my Lightning today. 56 bags @ 60 pounds each. I wouldn't recommend that to anyone, but it handled better than any of my prior ICE trucks with 500lb in the back. I was a whole different level of impressed today.
Why was he angry?
Not sure what was happening off camera. Seemed like he felt overworked and probably the only forklift operator onsite.
OK. I thought maybe it was related to the Lightning!
Jseis
Washington
I hauled a ton of brochures in my Sport Trac Adrenalin by allocating 40 pound boxes as if I was hauling 3 NFL defensive lineman in the 4 door cab. Then I put 1000 pounds in the bed. The trucklet was weighty but did fine. The boxes were perfectly sized to stack on the floor, seat, etc.
