Adaptive cruise control strangeness
Twebmstr
Robert
Tn
2023 F150 lightning lariat
Not sure if I'm doing something wrong or if I have an issue. Hoping someone else has seen this. Every time I get on the highway and set my cruise control at 65, it will go for about a half mile then try to speed up to 75 mph. I don't think I'm using blue cruise.. anybody help would be appreciated !!
Do you have speed sign recognition turned on? With a tolerance?
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
Yeah you’re using blue cruise with speed sign recognition turned on.
Twebmstr
Robert
Tn
I'll definitely look into that, thanks!
Twebmstr
Robert
Tn
I know it's been a while since I posted this, hoping someone is still watching this thread. It definitely has something, probably a setting, going on. This happens in multiple locations. I can turn on the blue cruise and set for 65 or 40 depending where I am. As soon as I pass a speed limit sign ( for 65 or 40) on that road it tries to increase my speed by 10 mph. Where in the settings do I look for settings related to this? Thanks in advance!
Pottsie
Huntersville, NC
2023 F150 Lightning Platinum ER & 2006 F150 XLT with 275k miles on it
Glad I’m not the only one. I’m having similar situations. I’ll be fine cruising at 65 mph and it’s keeping the distance to the car in front. Then when the car isn’t there it’ll shoot up to 80 mph for no reason. I do not think it has anything to do with the speed signs. Surly the system doesn’t use that Vs GPS mapping of the roads that allow BC and the associated speed. Plan to ask the dealer but haven’t had the time yet. Also I see it happening when trailing a vehicle. I’ll see the cruise get set to 80mph. Would like to hear others ideas or experiences as well.
Seems to me that it has to be a software glitch. Would be good if they allow a max limit as a safety feature if they can’t figure it out. Eg. Dot ever let cruise get set higher that 70. Make it a toggle option.
It uses both, been multiple reports of the truck spotting a speed limit sign for the off ramp (like say a 35mph limit for a curved exit) and the truck will abruptly slow down. Please double check the driver assist settings and turn off anything you don't want. Cruise control setting has 3 options if I remember: standard, adaptive, adaptive w/speed limit sign (can't remember if it calls that something different)
Pottsie
Huntersville, NC
Thank you for the education and I’ll check that out. I appreciate the reply.
