Blank screen 22 pro
Picnics
Chicago
Ford Lightning Pro Ford Lightning Lariat
General Contracting
For the past couple of days my center screen has gone blank. I shut it down and lock the car and start it up again a few times to get a screen again. This morning the key fob wouldn’t unlock it so i unlocked with the phone and it sensed the key so i could move it. Again with a blank screen. Then after shutting it down and restarting it the center screen did a long loop of the startup screen and went blank again. I guess i should pull the battery to reset it???? Seems like we should have a reset button somewhere.
I’ve never had this issue before after having it for a year.
Blaster
VT
F-150L PRO, VW ID.4
I know you can reboot sync by holding "radio seek right" and "volume down" button at the same time for a few seconds. Not sure if that would help, a friend with a bronco had their center screen replaced recently under warranty. Hope it's an easy fix for you.
Did your truck receive any updates recently?
Sometimes the screens act weird for a few minutes afterward or maybe one drive cycle at most, but persisting for several days is unusual.
Before going the route of pulling a fuse or the battery terminal, double check that you don't have any updates still pending install or trying to download, if clear, give it a shot.
Heliian
Look in the manual for the reboot procedure, it's holding 2 buttons on the steering wheel, those 2 buttons are different between 15" and 12".
Ford Motor Company
Official Ford Account
Ford
F-150
Lightning101
Manny
NorCal
Lightning
Had the same issue went blank and stayed that way for an entire day. I tried the soft reset however that didn’t work as it only resets the sync screen. The next day the screen reappeared. I’ve scheduled an appointment to take it into my local dealer.
