Backup camera blank
thorndike
Robert
Colorado
2023 F150 Lightning Platinum
This afternoon, my backup camera failed leaving both the backup and surround camera views blank. I shifted in and out of park to see if that would solve the issue. No dice. I shut the truck off hoping to reset the system. Nothing happened. Is this a known issue? I've tried searching but haven't found a solution.
The Weatherman
Dean
South Central KY
This the first I’ve seen on the Lightning, but there are recalls on this issue for several Ford models and years.
My wife’s 2020 Explorer has a CSP for this issue.
The Backup Camera is mandated safety requirement so if we see more of this Ford will have to issue a recall. But regardless, it’s a warranty fix so call your dealer for repair/replacement.
Might be a loose harness connection at the back of the truck, follow the cable from the tail gate to the bed an underneath, look for the connector, un-seat and re-seat to see if that helps at all.
You might check to see if prankster put a piece of tape over the camera.
thorndike
Robert
Colorado
Unfortunately, the car was parked at my house, and the nearest road is nearly a mile away. So no one was up here.
thorndike
Robert
Colorado
I will try that tomorrow.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi Robert. Can you send us a DM with your VIN and dealership info? I can look into this for you.
sstevetx
Steve
Mine has been blank once or twice in the short time I owned it, but it was fine the next time I started it up. I had my truck in for the battery module replacement and they said my back camera was "glitchy" and ordered a part to replace it.
Thunder1809
Doug
Washington
2023 F-150 Lightning Lariat ER, Carbonized Grey
I put another post in but mine did not go blank but I am getting beeping and warnings. No 360 camera and no backup camera. 360 image looks like rainbow arcs are coming from the side mirrors.
