ctuan13
- First Name
- Chuck
- Jul 31, 2022
- Pittsburgh, PA
- 1979 Continental, 2022 F150 Lightning, 03 Marauder, 2024 F350
Maybe jittery isn't the right word, but I've test driven multiple Lightnings besides my own and they all exhibited this behavior to me. Maybe I've just got a sensitive foot? It's more that I can ever so slightly perceive when the regen kicks off and the service brakes kick in and the transition isn't entirely smooth.Interesting yours is "bit jittery once you've slowed down enough that regen begins to fade out and the service brakes have to step" because mine is smooth as silk all the way to a complete stop on regen then the brakes apply after I have stopped. Maybe you should have it looked at?
I'm someone who always aims to drive as smooth as possible, from acceleration to braking, especially braking. I make it a point to come to a smooth final stop so gently that there is no final "grab" as the pads achieve static friction. This requires lifting off the brake pedal slowly as the truck slows down, but timed correctly with the deceleration of the vehicle. On convential gas vehicles and certainly on pre-ABS and brake force distribution cars like my Continental, it's linear and easy to gauge.
On the Lightning, it's finicky and never feels like it's ever in exactly the same place, probably because it isn't and it's the blend module trying to calculate the best time and pedal position to blend in service brakes and how much to blend in.
It's a nitpick and in no way takes away significantly from the truck, but it's something to note.
