Cannot understand onboard scales
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Loaded my 22 Pro with some metal parts the other day and had an actual use for the onboard scales. I knew the load was going to be at or just above the max rated payload. When I activated the onboard scale, it popped up a warning that said the load was over the max rating. Then when I dismissed the warning, it wasn't clear to me what the actual weight was. There was only one number displayed at the top of an all red scale - 2109 lbs. Not sure that number was the load weight or just marking the max end of the scale.
When overweight, it would be helpful; to know by how much - Am I 10 lbs or over 500 lbs over makes kind of a big difference in decision making and knowing how much to unload before proceeding.
That is the max load rating for your truck configuration.
There is no load number, only the bar graph.
The remote scale function in Fordpass was removed a while ago.
