Drivers door window cracked. Replacement cost and Part#?
That is all kindof funny to be honest. What is interesting is that this characteristic is the same for the ICE f-150s as well, so it can vary by trim but generally the higher spec trims have it as standard equipment. With so many of these trucks being made I agree with you that the cost should be lower.
If made well, an EV should be pretty much maintenance free, so they have to make some after sale money somehow, and it's always in parts it seems.
Some estimate that buying all the parts for a car would cost about 10 times what you'd pay for the car already assembled. I think that is a conservative estimate!
Biologyinsight
2024 Lightning Flash
Educator
So, I swapped out the glass. I timed the process as I was curious. It took me 3 minutes to remove and replace the glass including taking off the trim and replacing it. Maybe another 4 minutes if you want to add in taking the tools out and putting them back. I give this project a difficulty rating of a 1.5/5.
Robocop
2022 Platinum; 1962 Lincoln Continental
This is a very hilarious and educational post. Not sure if humour was intended but congratulations.
Frankly I wish they made the moonroof out of double paned glass as well......
