Bob_Mac
- First Name
- Bob
- Feb 6, 2022
- North Carolina
- 2021 Ford F-150 Platinum
- Occupation
- Cyber Security | Developer
There's 4 tests total and the doc will show the fourth one.No, not if used properly. Make sure you run the first three diagnostics under the Support tab of the J2534 Toolbox. This is important. The Mongoose must be plugged into the truck with the ignition on, engine off when running the diagnostics. If all checks out, you can then immediately proceed to FDRS.
