rdr854
Northern Virginia
The moderator said that the pro model will come with a key fob and key switch to start it (no start button) - huge miss by ford if that's the case. This is an EV not an ICE car from the 80's
Also said push button start is optional on XLT
Diabolical!
Lee
New Orleans
'11 F250, '17 Chevy Volt, '22 Lightning (Reserved)
One thing technical thing that just stuck out.....131 KWh useable capacity extended battery.
And 300 miles per charge? That rivals smaller, more aerodynamic EVs. I hope they can squeeze 300 miles from that capacity but it seems like a stretch...
JPro
Vancouver, WA
22 F150 Lightning Lariat SR
Rebar Detailer/Estimator
Another standout I noticed for all trim levels is that the LED headlights are “Dynamic Bending “
biers
Thomas
SW Washington
2022 Pro SR
Even Ford marketing struggles with kW vs kWh. 10-15% less useable capacity than what was expected. Means these are more efficient than expected. 2.3 miles a kWh. Not bad at all. Hopefully they are software locking some of the gross capacity and can open it up over time like with the Mach E.
Ford F-150 Lightning F150 Lightning Livestream (12/16) – Q&A, Specs & Infographics 2022 F150 Lightning Extended Battery Capacity
Ford F-150 Lightning F150 Lightning Livestream (12/16) – Q&A, Specs & Infographics 2022 F150 Lightning Standard Battery Capacity
RudeLightning
Rudi
Orange County, CA
22' Lightning Platinum, 22' Bronco Badlands
Better info on this presentation than the last one.
He made sure not to promise any exact time frames, just "order banks open in January".
I did learn that the Platinum with Max Tow will only tow 8500 lbs. I thought all models with extended range would tow 10,000 lbs?
Is there a site hosting a recording of these Livestream events?
Bippers
1965 Thunderbird 2014 Honda Accord
Chemical Engineer
XLT is looking more promising to me. I really want physical controls for AC and I don't like leather seats so that rules out Lariat+. If Pro is going to be delayed/sold out by my order time I would be fine with an XLT.
Griddlez
Griddlez
Metro-East of St. Louis, MO
300/131 = 2.29... with 1000lbs of payload. Doesn't seem bad if that is truly how efficient the truck is. What's the Mach-E? 270/98 = 2.76? Doesn't seem too bad at all.
greenne
Nathan
Niskayuna, NY
That works out to be 2.3mi/KWh. Rivian is 135KWh with 314...so that works out to be 2.33 mi/KWh.
Edit: Corrected calculations to be mi/KWh energy useage
JPro
Vancouver, WA
The graphic in the dealer order manual floating around that shows XLT and PRO trims as not being available in 2022, but the live stream answer appears to confirm that all trims are available.
Ford F-150 Lightning F150 Lightning Livestream (12/16) – Q&A, Specs & Infographics 0353F01D-DC07-405D-8324-FEDEF63F0C16
gorwell
Sacramento
Ioniq 5 / XLT Standard
I have to assume this is a chip issue. No way switching out the ignition between models Id saving money.
On the original spec sheet. All trims had push start.
gorwell
Sacramento
That works out to be 2.3KWh/mile. Rivian is 135KWh with 314...so that works out to be 2.33 KWh/mile
I'm having a hard time believing this :)
Either rivian failed at aerodynamics (kind of doubt) or ford found magical aero paint.
Alternately... EPA rating may end up a bit shorter than anticipated.
Snappy22
NJ
Honda Pilot, Honda CRV
What is a key switch? A normal “put the actual key in the hole” ignition? Does the fob lock and unlock the car? I’m guessing no remote start to warm the car either on fob, but ford app might have it?
