How often to charge to 100%?
chriserx
Louisiana
I'm likely in the minority with my setup, I have the Ford app set to 100% but through Home Assistant, throttle the charge speed based on charge level making it effectively 70-90% depending on my usage. Instead of having a hard cap where it stops charging at x%, it's literally always charging. Definitely helped out the LVB, haven't had an issue since, all without adding a maintainer.
To answer the question though, 100% for roadtrips 1-2x a month and 2 accidental 100% from lack of driving.
fhteagle
D
I go to 100% every time I leave my mesa, which is averaging a little under twice a month. I am seeing small but steady improvement across my 9 months of ownership in:
- time and wall kWh (measured by OpenEVSE) that it takes to go from 99% to 100% indicated
- Carscanner reported kWh available at 100%
I assume the previous owner rarely if ever went to 100%. Not having raw cell V data like I used to have makes this way more guesswork based for me though.
Now the bottom end of the pack, that I still have trouble getting to, trusting, etc. This is the only make/model to strand the Out of Spec crew ... 4 times I think total. And I really cannot come home at crazy low SoC due to a gnarly hill climb right before home + no bailouts available on any route ...
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
Thanks for all the input, everyone.
It's funny, seeing what Ford actually says appears to be the last place I look. Me just being lazy, I guess.
Chillguy
Marek
DFW
2023 Ford F-150 LIGHTNING Platinum, 2025 Chevy Blazer RS EV
real estate, infotech
My Lightning is my 5th EV in 15 years. I always charge to 100% when I plug in regardless of what anyone says and I plug in twice a week on average despite daily driving. None of vehicles ever experienced degraded battery performance...
SpaceEVDriver
Arizona
I regularly climb my 7000 foot mountain with the goal of arriving home with 0% charge so I don’t waste any money on DCFC prices. ;) But I only have a relatively level gravel road for the final 2 miles so I know I can get upward of 8-10 miles/kWh on that section without trying.
vvgogh
Colorado
'23 F-150 Lightning ER
When you charge to 100%, if you measured the energy used, you would find it using more kWh than the battery holds. This is the cells balancing. I have observed more than 10kWh extra. In short, those that always charge to 100% are spending unnecessary money for cell balancing that does nothing for their battery health, and unless they need the range is totally wasted.
I've also seen the > 10 kWh lost during 99-100% cell balancing into resistive loads. So, don't do it everyday. If your battery cells grow too imbalanced, the truck will throw wrench icon with Service Soon warnings and you might need a module replaced. The longer you go without cell balancing, the more a voltage imbalance can grow. So, perform a top-balance periodically. If we do lose 10 kWh into those resistors during a top-balance, performing this once a week costs <$100/y at my rates. I'd aim for weekly - $1k/10y, cheap battery maintenance much cheaper than ICE maintenance.
It's been posted the truck battery management software will balance if it's been unplugged and OFF for 48h. It's unclear how well this works in practice. As you can see from the top-balance's potential 10 kWh energy usage, the truck won't balance to this same level when OFF... the standard range would lose 10% if it did the same amount of balancing.
K6CCC
Glendora, Calif.
According to my charging session spreadsheet, I have charged to 100% 24 times out of 249 charge sessions. All of those were on L2. Almost half of those were allowed to go to 100% because it was free. The rest were at home because I was going to be making a long drive the next day. This is in just over 13 months.
Under normal circumstances, I charge to 85 or 90% at home.
bc1
McPherson, KS
I suppose the 2 mile hike home should be good exercise if it did shut down and an easy trip to go back and get it unless it regenerate a little on its own if it sits for a while. Getting stuck on a big city freeway during rush hour isn't a fun way to get exercise.
Lightningwaiter
British Columbia
Lightning Lariat ER
Construction
Just wondering if it's good for the battery to charge to 100% every once and awhile. I've had the truck since August of last year and it was 100% when I picked it up. I did a max charge for one mid range trip and that's about it.
I normally charge to 80%.
I change to 90% every day but only on longer trips which is not that often.
SpaceEVDriver
Arizona
I can’t comprehend running out of charge in an ocean of chargers.
Ragman
2023 Lightnings - SR XLT, ER XLT, ER Lariat - 2024
100% regularly, sitting at Tesla right now fast charging at 171 kw. At 100k km service (60k miles) had dealership test battery - 98.5%.
Charge it and drive it - my two cents. Ford did a great job with battery buffers.
msdickerson
North Central Massachusetts
2024 Ford F150 Lightning Flash
During the winter I charge at home to 100% daily, but when steady 50 degrees or above come in, then I do 90%. My J1772 (20 amp 240 vac) only charges at 4500 watts / @ 10mph . So it is not doing a fast charge.
LakeWorthLuke
Luke
US
2024 Lightning Lariat, Avalanche
Tech
I charge to 85% every day. I put on my calendar for a quarterly task of charging to 100% and disconnecting the 12v battery for 20+ minutes. Seems like a good thing to do quarterly.
edit: sorry, I don't charge *every* day, but just whenever I charge. I have a short commute so it's usually just 2-3 times a week.
Curious, why disconnecting the battery for 20 mins? What does that do?
JRDM2
J
2025 Lightning Flash
I charge almost every day to 80%, charge to 100% the night before two longer trips in the 4 months I've owned it.
FloridaMan655321
Banned
Banned
Banned
1973 F100, 2024 Flash
If you remember, or have worked in or around tech, when your operating system was having issues, the IT guy would have you disconnect the power from the computer, hit the power button to drain all the electrons/capacitors/etc.., then plug it in and power it back on. It’s kind of like that with vehicles these days. They are like operating systems of the past and sometimes you need to drain all the ‘juices’. Giving it the ole ‘cold boot’
