mathis1
Ronny
Norway
F150 Lightning PRO 2022
I'm a little confused. In your pic, the small rectangular light that is brightly lit is the DRL. Are you referring to the plastic light bar shaped like a "7".
I see you're in Europe. Did you have any reconfiguration work done when you imported it?
Sorry, I thought the "7" LED was part of the DRL. Yes, it's the "7" that is not lighting up. The DRL square is working as it should. The car is not part of the fleet of cars that has been altered for the European marked, but someone has changed the LDCMA module. The right side is working as it should.
The "7" is part of the parking lamp system along with the light bar on XLT and above. Did it work in the past or is this a used import you just acquired? From your codes you might legitimately have a open circuit to that lamp.
There are folks with XLT and above that have had issues with only half the light bar coming on. Your issue may be the same as theirs.
Also, it would be great if you added year to your Vehicle Details in your Account Details. :)
