Key Not Detected Error
Lytning
Georgia
I have had multiple "Key Not Detected" errors in the past 10 days. The first occurrence was immediately after activating the climate control system from FordPass 5.0. However, since then it has occurred another 8 to 10 times without FordPass involvement. I tried the spare key fob, and the problem persisted. When I place the key fob in the emergency key fob slot, the truck recognizes the key. The truck then usually recognizes the key fob for a few times after the emergency slot start. I have replaced the CR2450 batteries in both key fobs, and lifted the 12 volt negative terminal from the battery, but the issue continues to occur. Is anyone else experiencing this issue?
The Weatherman
Dean
South Central KY
I have had a few occasions in the past two weeks where it took sometime before the truck recognized my PAAK.
After several attempts to start the truck it finally worked. I also had to start the App before it recognized it.
Lytning
Lytning
Georgia
Thanks. I am not using PAAK.
The Weatherman
Dean
South Central KY
My bad. I don’t know why I originally read it that way.
maverick129
2018 Expedition
Same with mine. I use PAAK and my iPhone is connected to CarPlay at the truck says no key detected while driving. Weird.
srspring551
Scott
WI
I have had random "no key" events, usually brief. I have PAAK. I have suspected that Ford ramped up requirements for PAAK, because... who knows? It used to just flash "PAAK works better when FordPass open," but now sometimes it actually requires it. I usually keep my key fob with me, but in a faraday sleeve.
Blochead21
PA
Black 22 XLT 311pkg
It happens regularly on ours as well. We don’t have PAAK and just use the fob.
