Looking for a cheap and good solution to prevent items from sliding in the bed
BLoflin
Brooks
Austin, TX
2022 KR PB 6.5'
Didn't mention it before, but I have spray-in bed liner, but also the Ford rubber mat. I think the mat only adds 30 to 40lbs. And of course it can be taken out. Rubber mat does prevent most stuff from moving around much (i.e. if I put suitcases, etc,) UNLESS I have a panic stop...
Finally on my previous F150 I had the foldable/flippable "bed extension" that someone else posted. It worked well for keeping a limited amount of stuff near the tailgate. Decided on not getting one this time. Just using the collapsible bag I talked about in my previous post.
Reactions: sbi
Graygoose2021
Central US!
2021 F150
Sales
sbi
Upstate SC
2021 F-150 5.0 Lariat SCREW Space White
Graygoose2021
Central US!
2021 F150
Sales
Ah gocha. Cheaper :)
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed 1646941164224
Blueshound
Connecticut
2021 F150
My main objective is to prevent items from shifting in the bed. Could be grocery bags (plastic or reusable), a box of something, a suitcase, etc. That's why I am trying to avoid a divider; I don't really want a divider. It works fine for every day use, but I am too lazy to climb onto the bed to remove it if, for example, I need to drive someone to the airport with a suitcase. I know, crazy excuse....that's what happens when you get older ?.
So ideally it would be a non-slipping surface, but I am also sensitive to weight - I don't want something too heavy either. Not sure how much the rubber mats weigh. I have the feeling the Bedrug mat is lighter than the rubber one.
1x10 (not 2x10) leaves plenty of room for 2 or 3 suitcases, and is light enough to lift out with one hand. Unlike a shower rod, things can't slide underneath. I may eventually add a rubber mat as well, but I like the ease of sliding things in and out with the plastic bedliner. Paper grocery bags don't slide around, they don't allow plastic bags here anymore.
Sundancer330
2021 F150 XLT, FX4, Velocity Blue
Just use the backseat area, I sure dont want groceries spilled all over the bed.
rpeterslll
Rob
Livonia, MI
2018 F150 Lariat FX4 Sport
IT Professional
Ford Rubber bed mat works good for me.
Reactions: sbi
3DogKnight
Minnesota
2020 Escape Titanium - 2021 F150 XLT
100% retired
I know the Bedrugs rugs keep items from sliding in the bed, but I am hoping to spend less than $168. I have a Line-x spray in and it doesn't have to look nice because the bed is covered anyways. I am looking for something that will prevent grocery bags, other stuff, from sliding back and forth in the bed. Any idea will be appreciated.
Thanks.
This is what I made to keep gas cans, chain saw and other stuff from sliding forward in the bed. It's easily removable and didn't cost me anything because I usually have a lot of scrap wood laying around. The pic's were taken when it wasn't completely finished.
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed 16EF7C38-9C76-4986-ABD6-0D9F4D9A60FB_1_201_a
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed E9C1157E-BFA1-455A-9C5A-1B9CF8E3C195
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed A5C892CA-EC50-4FC4-B75E-37118C4A129C
sbi
Upstate SC
Looks good.
spud_41
Mountains & Desert
'21 Lariat 502a, Lead Foot 3.5L EB Fx4
When I got WeatherTech mats I threw the OEM rear rubber mat in the bed to protect my skis. Works pretty well, and easy to take out and throw wherever.
D2thejr24
DJ
2021 F150
The most versatile solution is an adjustable shower rod. They expand and have fine screw adjustments to make them tight, buy two ($12-$20 each) and then you can create cradles to retain any variety of sizes of cargo.
Or if you don't like the shower curtain rod idea, they do make 'small' cargo retaining rods, similar to what 18-wheelers use, but they run about $40
https://shop.advanceautoparts.com/p...KSwvo_lgUc361DkovjBoCT20QAvD_BwE&gclsrc=aw.ds
I like the shower rod idea!!!
Pedaldude
Arizona
2001 Lincoln Navigator, 2021 Ford F-150
I use a milk crate to keep small stuff from rolling around and a Tractor Supply horse stall mat to keep the bed from getting too banged up or resonating over bumps. The mat doesn't keep things from sliding unless they are on the heavy side and you drive like you're eating a bowl of cereal.
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed F000F3FF-D01E-425B-B2B1-CFF8ACFCA40C
Eric
Eric
Toronto
2021 F150 XL STX
You get six giant totes($16 CDN each) from Home Depot. They will fill the bed with a few inches to spare between them. The ones closest to the tailgate are for things that go in and out the most(groceries).
Keeps your stuff clean because there’s usually dust and stuff in the bed. And when you need the space they all stack into each other and you can stick them in the corner or just put the whole stack in the garage if you need the whole bed.
Ford F-150 Lightning Looking for a cheap and good solution to prevent items from sliding in the bed E618CF37-3256-4FA7-9A88-D8B3610C4AFD
UGADawg96
JAX, FL
302A 157 PB
I usually put groceries and luggage in the back with the seats up and use a bungie to hold the yard tools gas can in the back of the bed when refilling it. I do like both the trucker/shower rod and the wood plank idea for temporary holds if really needed, but I haven't made the effort to procure those since I haven't really experienced a sliding load.
