Lytning
You can check availability for your electric utility provider at this link:
https://shopgenerlink.com/pages/check-utility-approval-status
@Ford Motor Company, thanks for the update.We collaborated with Global Power Products to make their GenerLink transfer switch operate with both the F-150 PowerBoost Hybrid equipped with 7.2 kW Pro Power Onboard and F-150 Lightning equipped with 9.6 kW Pro Power Onboard. The magic piece here is the Ford Vehicle Connector. This 12-inch cable was co-developed with Global Power Products (the manufacturer of GenerLink) and is what makes the connection possible. It prevents parallel electrical return paths, ensuring the truck’s GFCI sensors do not 'trip' and cut power from your truck to the home.
Right now, this is a pilot program rolling out in UT, TN, GA, and NC.
I checked the FAQ, but don't see the pilot status mentioned. How long is the pilot expected to last? If the pilot is successful, will this solution be made available nationally? Or is it something that would be state by state?Right now, this is a pilot program rolling out in UT, TN, GA, and NC.
Should spin up a pilot with Hydro One up in Ontario, Canada. I would gladly be a test subject for this when it becomes available here!Hey everyone, I wanted to jump in and officially confirm the details of this new pilot program. The details I gathered are below.
The hardware bundle is $1,100. If your utility company approves the transfer switch installation right on your meter, then anticipated installation ranges between $250-$450. For those that have a utility that does not approve of on-meter installation, there is a next to meter solution, where the installation costs are increased with anticipated ranges between $1,000 to $1,500.
Instead of running cords through doors and windows, this direct-to-panel connection makes using the 7.2 kW Pro Power Onboard a breeze. It puts you in control of your home’s energy, allowing you to easily manage and power your essential home systems using your truck’s built-in power during outages.
In the meantime, you can find more details on our partner site here and in an FAQ here.
Don’t feel bad. Duke energy of course don’t even offer it. Sorry bastards I’m in NC@Ford Motor Company, thanks for the update.
I request that Ford and Global Power Products work with the electric utilities to address and resolve any concerns they have to allow the on-meter installation.
Cobb EMC, my utility in Georgia, does not approve the on-meter installation. They can't provide me with a reason other than a concern for reliability and maintenance. The next-to-meter installation almost doubles the total cost over the on-meter installation. Adoption and use of the product will obviously increase significantly with approval of the on-meter installation.
So it just omits the ground conductor, right? I mean that's the only way not to trip the truck.Hey everyone, I wanted to jump in and officially confirm the details of this new pilot program. The details I gathered are below.
