Firebelly
Yes that's a good solution too. It has always seemed a little chintzy to me that a little strip of sheet metal is the only thing preventing you from incinerating your truck, or at least the pro power. But if people are using them and they work, that's great.Your electrician can install a generator inlet, and load panel interlock kit for so much less and as long as the interlock is UL listed should be legal in most states. No transfer switch and you can select any of your current breakers to power. I don't see what makes the generlink system any better. You still have to turn off your main breaker. You still have to carefully choose what breakers to turn on or keep off to keep it under your generator's (or PPOB) max output. Interlock and Inlet Box
