Parking Sensors Fault
Ajm97
Lariat ER '23
I've been getting this warning every start for several days. Initially thought it was because the sensors were dirty, but after a good wash and wipe and a couple of ignition cycles, the alert still pops up.
Anyone else encounter this?
Easy fix?
Ford F-150 Lightning Parking Sensors Fault 1000004930
Lucky Larry
Calgary, AB, Canada
23 Lightning Platinum, RX 350, Pontiac Solstice
i have had a similar problem recently with the message "front parking sensors are not available" We have had a lot of slush on the roads recently which freezes on the vehicle while driving blocking the sensors with ice. I was able to fix this error by cleaning the sensors with isopropyl alcohol and then going back and putting a small amount alcohol on the sensor with a syringe, this seemed to work well to clear the ice and error message.
Are you starting inside a small garage or close to an object?
Ajm97
Lariat ER '23
@Heliian in th morning, yes, from in the garage (but I've had the truck for over a year without that issue) but after work it's outside in a parking lot.
Ford Motor Company
Official Ford Account
Ford
F-150
Easy fix?
Hi there! Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and I’ll look into this parking sensor concern. Thanks!
dkrueger
Pennsylvania
2023 F-150 Lightning
Easy fix?
This is a known issue. I bought my 2023 in early January and the sales person told me this was an issue and that Ford would have an update to fix it. I brought it in for service twice and they installed updates that fixed it. Take it back to your dealer and ask them to update.
2wheeltraveler
Austin, TX
2022 F150 Lightning Lariat Rapid Red
I've started seeing about once a week lately (maybe 5 total), not clear if there is a pattern, but it's rare and hadn't happened in the previous 24k miles.
maineiah
US
2024 Ford Lightning Platinum
Exact same issue here. Started happening after an ice storm that the truck was parked in. Not sure if that kicked it off or not. Regardless, dealer bound.
PS excellent range
Ford F-150 Lightning Parking Sensors Fault IMG_2908
Ajm97
Lariat ER '23
PS excellent range
I think mine started driving through some crappy winter conditions too... Which is why I thought it was just covered sensors...
Im booked in a couple days, I'll update what they find/ do...
Ford Motor Company
Ford
F-150
PS excellent range
Ajm97
Lariat ER '23
Mine turned out to be a corroded wire running to one of the sensors.
maineiah
US
Any luck? I haven't been able to get over to the dealer yet...
