RLXXI
- Jun 10, 2021
- S. E. Louisiana
- 2025 F 150 Flash, 2013 F 150 XLT, 2014 Escape, 2011 Suzuki DR 650SE
- Occupation
- Auto tech
That solution did the trick, I got the timer you linked and a small 200W heater, dash cam ran all night long. Woohoo!! Thanks for the tip.You'll need to apply a load (~100W) once for a few seconds every 5 minutes to defeat Ford's auto-shutdown, or you'll need to keep the truck running. I suggest a short interval switch and a personal space heater.
Another option is to daisychain your dashcam to a power bank (that supports passthrough charging) which is plugged into the truck. Assuming you drive the truck once in a while, it will charge the bank, then the bank provides continious power to the dashcam.
