Pro Power reserve limit fails
I <3 My Lightning
I have not fully tested mine but when I choose closest charger, it too defaults to 10 miles. Meanwhile the closest is 2.
Some update also took out the reserve from the app...see my past post quote...
Has anyone played around with the "search" setting for the type of charger? Does this make a difference? For example from the app, but also can be done in the truck.
Ford F-150 Lightning Pro Power reserve limit fails Screenshot_20260508-150656
The changes. I can now edit the name of target charge location in the app.
And the pro power now shows the frunk/cabin and bed outlets as separates when off, instead of a single statement item. Also it shows what I have the reserve set at. Before that did not exist.
dmd3home
Central Coast CA
2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
The problem really seems to be hit or miss as I used the feature last week and it seemed to work fine. But this week is a different story. BTW, though it shouldn't make any difference, the 12v battery was fully charged as I keep it on a battery maintainer when I'm not actually driving it.
I really need this feature to work!....I can't be running out there to reset everything every 30-60 mins.
K6CCC
Glendora, Calif.
All I can say for sure is that I have slept many nights with the PPOB powering my CPAP machine (which draws only a few watts) either by leaving the truck on (disable the powerdown), or using a short interval timer and 100 watt heater. Never had PPOB shut down on me. I have also regularly left PPOB on powering a battery charger / power supply that is powering some radio equipment.
This is on a 2024 Flash which always have had the ability to leave PPOB turned on with the truck turned off.
EVpower
Northern California
2023 F-150 Lightning Lariat, Bronco II
Electrical Engineer
Have you had a light load on the bed outlets when PPOB has incorrectly shut down? I am wondering if software for the 24 version of Pro Power which has a light power load auto off feature may have been loaded.
I had the 240V outlet running the house (about 1kw) but nothing on the 120V frunk outlets when it shut off suddenly..
I have a 2023 Pro, and the OP has a 2023 MY as well as @I <3 My Lightning
Maybe it is a 2023MY issue?
I had it happen with the truck OFF and PPOB ON, but the OP had the truck ON when it happened.
An OTA screwed something up on our 2023 MY trucks.
No easy way to undo/rollback these updates when they foul things up like you can with a PC.
I wonder if we could use the "AS BUILT" settings from FORD - but that would undo the good with the bad I suppose.
If we knew in more detail WHAT THE FUDGE the malformed OTA changed, maybe we could fix it with FORscan or FDRS...but no idea which module or modules got screwed up.
@Ford Motor Company : Brian we need a fix.
