cal
- First Name
- Cal
- Jun 26, 2023
- Battle Ground WA
- 2022 Lightning, Tesla Model S Plaid
- Occupation
- retired
Ok shortly after I got my Lightning I bought a 7k dump trailer for home use. Owned a single axle utility trailer in the past but it didn't have trailer brakes. So the dump trailer has a battery to raise and lower the bed. Unfortunately there is no power where the trailer is stored. Pretty sure I'm done with it until spring so I took the battery out to keep it trickle charging in the garage.
There are two questions that came to mind. Can I operate the dump without the battery (using the power from the truck trailer connector)? I don't think so because the cables to the pump are pretty big. What about driving without the battery? I know the emergency brake is activated by that battery so it would be inop if the trailer disconnected but I assume the regular trailer brakes would work fine.
Second question. When I rented a 45' electric boom to work on our greenhouse I noticed that just having the trailer connected to the truck partially drained my battery (loss of range miles). Pretty sure it's because I didn't have the boom completely turned off over night. Is this normal? I thought the only thing the truck's trailer connector did is activate lights, turn signals, and the brakes. Does it do more? At that time the truck was still pretty new to me and maybe I didn't turn it all the way off.
Thoughts?
Thoughts?
