(RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared
iceman77
Pete
Dallas
2022 Ford F-150 Platinum
Just as the title says, SecuriAlert as well as OTA Updates disappeared from my FordPass application about 2 days ago. I did a manual GWM update to "EKB" revision via FDRS which was successful. Not sure if that caused it, or there is a glitch at Fords "mothership" servers:
Ford F-150 Lightning (RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared 99B021A2-A61A-4FF6-98DA-97598C5F215B
Ford F-150 Lightning (RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared C030F0F3-946D-408D-8F08-F6D335E6D153
What's even more concerning is that @tonesto7 "hidden" OTA message shows following:
Ford F-150 Lightning (RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared 1642373519023
Truck does not show any DTCs to any modules related to OTA and SecuriAlert. Anyone experiencing same/similar issues. Especially those who performed manual GWM update ?
iceman77
Pete
Dallas
I fixed it this morning. Seems FDRS uploads and modifies your As-Built after your initial Network Scan. It uploads changes made to module configurations as well as SW revisions of your modules. In my case, the GWM SW revision got corrupted during scan (or upload):
Ford F-150 Lightning (RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared 1642468975157
All I needed was to launch FDRS and re-run network scan and that corrected my As-Built SW revision info for GWM:
Ford F-150 Lightning (RESOLVED) FordPass - SecuriAlert, OTA Updates dissappeared 1642469071450
And voila! OTA and SecuriAlert is back in business!
heffer86
Iowa
2021 F150 Lariat 501A
Great you got it working. Where did you pull those config files from on your PC?
iceman77
Pete
Dallas
You can pull your As-Built either from PTS (if you have access to it) or motorcraft website here. I managed to save a copy before GWM update so I had data to compare against. Took me a good while to figure this out...
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Does this suggest that you should always do a follow-up network scan after every module update to make sure nothing in your As-Built data got corrupted?
iceman77
Pete
Dallas
i think this was an isolated case caused perhaps by network disturbance (by weak wifi signal to my laptop) or a bug in FDRS software. Don’t know for sure. Should you get such issue as described in OP, a simple network scan would fix it
JEB
Northern Illinois
Got it. Thanks. Good catch on your end.
DeltaDeuce
Dallas, Texas
21 F150 Platinum Powerboost 701A High
So if I download that as built file how do I upload it into FDRS?
iceman77
Pete
Dallas
You can’t! FDRS submits all HW/SW revision info automatically at the end of network scan
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
As mentioned in other thread, both of mine are gone now too. I’m pretty sure I reran net scan again. Just happened to notice exactly what you mentioned here. Ugh.
BHunted1
Sumner County TN
Reran the test several times this morn. No joy. FP still missing security and update screen.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
In my last scan, I had the blank APIM version in FDRS, but still have FP updates & Security.
iceman77
Pete
Dallas
Whats important, that you shut down FDRS between individual Network Scan sessions. It seems only the intial Network Scan result is reported to Ford servers. Any subsequent scan does not. At least this was my observation
BHunted1
Sumner County TN
First I heard that. Pretty sure I tried that but I have one more day. So will try first thing in morn. My brain hurts.
BHunted1
Sumner County TN
Following icemans procedure above resolved my missing headlight, securealert stuff missing. Also gave back the data to the widget ap.
Thanks Pete!
