Retractable ratchet straps seem like an amazing idea, anyone tried them?
SFsparkie
2023 F150 Lightning Lariat ER 01/23
I have had two mounted on the left side for several months
https://a.co/d/cSBDNcX
They functioned great straight up and down. They did not twist at an angle because the bottom of the ratchet assembly rubbed against the bed wall. I solved the problem with longer bolts and spacers between the bed wall and the ratchet strap mount. Hopefully other models don’t have this issue.
Ford F-150 Lightning Retractable ratchet straps seem like an amazing idea, anyone tried them? IMG_8519
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
I use CargoBuckle G3's. I didn't permantently mount mine to box links through, but they do stay strapped there when not in use. They hold my side by side in the bed, among other things (see pfp).
I just use the Rhino Retractable straps. They work great fit fine under the back seat.
https://a.co/d/ev7lklW
I've never tried "auto-self-retracting" straps, ever have any trouble with that feature?
Sure is a pain sometimes cranking straps back into the coil.
