Safety Program: 25S18 aka 25V131: HV Battery Electrode Misalignment Discussion
Has your truck been listed for the 25S18 recall?
  • Total voters
    67
Old Aviator
Larry
WPB, FL
Consultant
Got mine back yesterday. Based on the work sheet some heat-shields and another item (i assume battery module were replaced) . Charged it up to 90% (on my house solar system) and backed it into the detached garage. Will drive it today. I'm happy it was not torn completely apart. Don't fix what ain't broken.
I'm not sure your two statements go together. You assumed a battery module was replaced, but you also note you are happy that it was not torn completely apart. If they replaced a battery module, your battery was dropped from the truck and disassembled to get the new module in. It was torn apart.
Wattsgas
MIke
Brinnon, WA
Similar experience to you. Dealership had my truck for 3 weeks. It took a week for Ford and the Dealership to determine the fix. Another week to get parts. One module was replaced. So, for my truck this is the second module that has been replaced. Like you I am glad to have my truck back, and the ability to charge to 100%.
Davis
Las Cruces, NM
2022 F150 Lightning Lariat SR
Small update. Dealership pushed our appointment back for three weeks (dropped off Monday, was originally scheduled for July 7). No explanation, but I don't mind since the truck was perfectly drivable, hopefully it was to order parts (but I'm also a realist). When I dropped it off he was still saying they would need to inspect it before ordering modules.
Got a loaner, 25 F150 Hybrid, it's nice but not a Lightning, also, that transmission shifts like a drunk when it's cold. The brake booster is also super noisy when it's in EV mode. Makes me appreciate the Lightning all that much more. The familiar ding while backing up is mildly comforting though.
I know Ford only pays loaner for three days, but my rental paperwork said 4 days, which is today. Definitely not encouraged by the updates I've seen here, your trucks being gone for multiple weeks! Seems like Ford really does their best to make the process quick and well documented, only for the dealers to literally not follow what's written in the process.
GoodSam
Good
occupying space
" I know Ford only pays loaner for three days, but my rental paperwork said 4 days, which is today. Definitely not encouraged by the updates I've seen here, your trucks being gone for multiple weeks! "
Dropped off my truck 7-9, went on vacation 21 days, avoiding extended rental costs for Ford (it is possible to get more than 3 days, "just" have dealer get OK from BEV team and another Ford entity) but dealer only recently dropped battery to do the stupid @Ford Motor Company module serial number confirmation inspection. So now getting the dealer authorized cheapest Enterprise Hyundai rental at about $60/day (auth for 8 days, can be extended), of which Ford will only cover $40/day worth. No ETA on the three modules that need to be replaced (my build was October, 2022, SR).
Customer notification says: "Your dealer is authorized to provide a rental vehicle for your personal transportation at no charge (except for fuel and insurance) while your vehicle is at the dealership for repairs. Please see your dealer for guidelines and limitations."
https://static.nhtsa.gov/odi/rcl/2025/RCONL-25V131-2429.pdf
Dealer four free Mazda loaners were already taken. Very poor customer support for their problem, that should be charged back to SK On, at no cost to Ford. Probably a Chevy EV will be our next buy unless I can reach Jim Farley on X.com and he responds with full reimbursement. I will see if BEV customer "support" changes their tune when I show the "no charge" statement of the recall.
instantfob
Denis
Gotham City West
2022 Lariat SR
Cat Herder
I got lucky that the truck was in for other warranty repairs. Having PremiumCare ext warranty gets you day 1 rental coverage. I drove around the 1.5T Bronco Sport for a few weeks. Worth getting ext warranty regardless of keeping it past the factory warranty. You get prorated refund if you sell your truck early.
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
MODERATOR EDIT 7/1/2025: Source Post #205
Link to the NHTSA documents:
https://www.nhtsa.gov/?nhtsaId=25V131000
Dealer repair steps, 21pgs:
https://static.nhtsa.gov/odi/rcl/2025/RCMN-25V131-0005.pdf
MODERATOR EDIT 4/29/2025: Source Post #153:
Latest notification https://static.nhtsa.gov/odi/rcl/2025/RIONL-25V131-1511.pdf
Interesting as there is no fix and we are being told don't charge past 80%
Campaign/NHTSA#
25S18/25V131
Issue Date
2025-02-28
Description
On your vehicle, it may be possible for an internal short circuit in the high voltage battery to occur after repeated charge and discharge cycles.
Safety Risk
If a short circuit occurs after repeated charge and discharge cycles, there is an increased risk of a vehicle fire. Owners can reduce this risk by limiting charging of the high voltage battery to 80 percent state of charge before new battery arrays are installed in your vehicle.
Remedy
Parts are not available. Ford Motor Company is working to provide parts for this repair. When the remedy becomes available, Ford Motor Company will notify you via mail to schedule a service appointment with your dealer for repairs to be completed free of charge. The remedy is anticipated to be available in the second quarter of 2025.
I'm going to pickup my truck after the dealer having it for a week. It seems this recall is all about a particular HV battery module. And in my case that defective module was 1 of the 3 battery modules that I already had replaced. So my dealer had to drop the HV battery to get serial numbers to ensure I needed that module replaced, before they'd send out the new module. Since it had previously ben replaced all the dealer did was reinstall my HV battery.
GoodSam
Good
occupying space
Any limit on what Ford would pay for rental? Or was this just a loaner from the dealer?
GoodSam
Good
occupying space
Let's see, truck given to dealer 7-9, and the three HV Battery modules finally replaced and in testing on 8-23, a seven week process, due to small dealer and only one combo Tech/ShopForeman. Open stalls to the environment seems less than ideal on days with fire ash coming down. Also, now work on getting GPS to properly find its location. TCU and Antenna replaced. Dealer Tech awaits more instruction from Ford Techs on Monday 8-25. Maybe get truck back 8-26. Hope Ford covers the Enterprise Hyundai Elantra rental fully at almost $60/day. Here are some pictures of the SR battery modules:
https://photos.app.goo.gl/nnfLVDN6q9pMUHgy6
Traconesu
Patrick
If it means you get a new battery, you kind of are ? As long as it doesn't fail while you're driving, and the repair doesn't take forever, of course.
Just a new module. I wish it had been a completely new battery.
Davis
Las Cruces, NM
Finally got the truck back yesterday. Total time at the dealer was 3 weeks and 3 days.
They let me keep the hybrid F150 the entire time, spent ~$200 in fuel and put just over 1000 miles on their truck, even though we tried to not use it as much as possible just to "play nice," and I'm always worried about damage/other drivers whenever I have someone else's vehicle.
Paperwork reports three modules were replaced, modules 1-3. They did quickly show me the paperwork that they said was what they would be billing Ford, to the tune of about $28k. They mentioned part of the long delay was that one of the batteries in the original set they received had a part damaged in shipping. Ford told them they would replace the damaged part, but unfortunately it was on back order, so the dealer just requested Ford send another whole module, and they did.
Took longer than I would've wanted (total time invested was about 2 months, including the original appointment getting pushed back weekly for a month), but ultimately the SA kept me in the loop with periodic updates and they let me keep their loaner the whole time, all's well that ends well.
Man it felt good to get back in the Lightning though, really is an incredible machine. Here's hoping it keeps going for many years to come.
Now it's time for a deep clean and detail over this nice long weekend!!
Edit: missing word
Davis
Las Cruces, NM
Interesting development, SA emailed me this morning and asked for a scan of the letter from the notification.
He's saying that the recall was "cleared" from the VIN and their warranty submission person was inquiring why they performed the recall work on the truck. I searched my VIN on Ford and NHTSA and both state there are no recalls open for my VIN. On the service paperwork there is a note from the tech that literally states he verified the VIN in Ford's service portal and saw the three battery arrays that needed to be replaced, so I guess that's good.
Anyone heard of this before? Any idea what this could mean?
