SmartchargeNY and Con Edison
pjy
Pat
Westchester Ny
F150 lightning
LE
New York has a utility incentive through SmartchargeNY and Con Edison (utility provider). The program worked from August through mid November and then Ford Pass started blocking the 3rd party tracking software. Ford support and SmartchargeNY have been unhelpful in resolving this. The discount is pretty significant (.10 a KW) along with other incentives. Anyone else’s havering this issue in NY or with their utility provider?
I have the same issues with the Mass (National Grid) version of the same program.
Only real solution is to buy a compatible EVSE and let them sample the data from it instead of the truck.
pjy
Pat
Westchester Ny
F150 lightning
LE
I bought the Tesla universal charger before this issue came up and unfortunately SmartchargeNY can't communicate with that either. Was trying to avoid buying another $600 level 2 charger, but it will end up paying for itself in 6 months with the incentives.
incTomi
2025 Ford F-150 Lightning Flash
Street
Just got a 2025 flash and running into the same thing in Coned smart choice website that F-150 lightning is not supported. What did you end up doing? The savings look to be significant so I definitely want to take advantage.
