BillsMafia21
- First Name
- Dave
- May 6, 2026
- West Falls, NY
- 2022 Ford Lightning
- Occupation
- Carpenter
So this is my first time posting...on any forum. I'm more of the "sit in the back and listen" kind of guy. I've visited this site many times for research and information. Anyways, I bought a first generation 2022 Lariat Lightning and fell in love right away. The first 3 years were "good" (lots of updates, lots of glitches) A little over a month ago I was out with my family and when it was time to go home I got the "stop safely now" and the car would not start. I tried waiting, disconnecting the 12V to no avail. Flat bedded to the dealership. Of course it sat there for a week with no one looking at it. While it sat there, I went over myself and replaced the 12V battery as I found out the 12V should be replaced every 3 years. Tried to reset the BMS but it was still stuck in the stop safely mode. When they finally got it in the shop they said there was a bunch of modules that had to be reprogrammed and that there was an issue with the cruise control system. After another week the technician deemed that there was an open circuit in a wire harness behind the front bumper.. all set, $650 plus the new battery. $650 was manageable but the 16 days without it was tough (I run a carpentry business) I get home and charge up and the wife asks to take the truck for a trip. She tells me the AC is not blowing cold air. I re-set my preferred changing times and called it a night. Next morning I have a charging error on my phone and the truck is back in the "stop safely now" mode. I test the 12V battery and it is showing 11V on my tester. I trickle charge up to ~15V but no luck. The dealership sends a mobile tech and the computer is coming back with a high voltage ground code and he said it will be another flat bed trip. Another week later they start into it. It seems they get the truck to move and charge but say the SoC is an issue and some code relating to the high voltage system. After they exhaust their ideas of how to diagnose the problem they call up Ford and they tell them to run the heat for 20 minutes while testing and then run the AC for 20 minutes and test. They tell me the AC isn't blowing cold air that the freon is gone. They tell me I need to fix the AC to continue diagnosing the high voltage issue. A couple days later they tell me a hot and cold port hose are leaking and that it will be $3300 to fix the AC and this won't fix the high voltage issue, just let them continue to diagnose. I'm furious at this point as I'm now on 6 weeks without the truck. I've contacted Ford directly and they are trying to work with me. I can't justify spending $3300 to make the air cold in a truck that doesn't work. And if they need to fix this to "fix" the high voltage issue then I believe it should be covered under the 8yr/100,000 mile warranty. They say the part is not covered. The truck has 65,000 miles and I don't see an end in sight for this problem. The quality of this vehicle is very disappointing and I believe it is a result of Ford trying to get the first EV truck on the market. If anyone has any insight on these issues it would be greatly appreciated.
