Swing out fender box
JRT
Huntsville, AL
Lightning
I saw this swing out box and thought it would be a great addition to store hitch, bungee cords, ropes, cargo straps for easy access to bed stuff.
It was easy to install, about 20 minutes and for the price seems like a winner. The removal of taillight wasn't hard, but the forward bracket was not perfect to align the screw holes. This was a bit of bending and opening up a hole with a drill bit. The reviews noted this was an issue so I expected it.
VEVOR Truck Bed Storage Box, Swing Case Fits Ford F-150 2015-2021, Passenger Side, Lockable Wheel Well Tool Box with Password Padlock, Waterproof and Durable ABS Tool Box https://a.co/d/8ZcMQVn
Ford F-150 Lightning Swing out fender box 20240130_104844
Ford F-150 Lightning Swing out fender box 20240130_104903
These seem to be exact copies of Undercover brand swing cases. I got this for $119 and a $20 coupon off so for $99 was a great deal.
Reactions: dww
Pod
2023 AMB Lightning XLT SR
I have my original Swingbox from old truck. Fit is not perfect and it will not stay latched. You have any problem with your latch mechanism?
JRT
JRT
Huntsville, AL
Lightning
No the latch mechanism on the bracket is adjustable up and down to line up with the rod.
davehu
hot springs, AR
had one on my ;;;;;2012 Avalanche and loved it. It was an option on my Lariat and added it without even thinking about it. Love it!
mb0220
Matt
2022 Lariat ER
I want to know about that bed mat. Can you share details on where you got it? I have the rubber one from Ford, but I like yours with the high sides.
Smokewagun
Bob
N. Illinois
2024 Ford Lightning ER
I have one on each side. Moved from my 2022 to my 2023 to my Lightning. Mine were a gratuity from Ford, otherwise I would have never spent $450 on the pair. Ford labeled.
Mine fit like a glove, although I expect if overloaded with weight, the latches might not latch perfectly. Love the storage, but they do waste space.
JRT
JRT
Huntsville, AL
Lightning
So a few things when I installed fast yesterday bugged me. So I watched the Undercover swing case install and realized I could keep the box link brackets and install the tie downs behind the bracket. I redid it this way. The only issue is the corner tie down hits the box when closing. I simply reversed it toward the bed, not as much room to hook on but still available to tie a rope or bungee cord if needed. I think the actual box can be adjusted out by removing the bracket and shifting it one screw hole mount, but honestly I'm fine with this for now.
My liner is Weathertec Impact liner and I did pick it specifically to have the higher sides, the material is also grippy and doesn't let stuff slide around. It has rubber suction cups on the bed side that stick it down and give the nice impact quality. I've had bed liners, mats, rugs and spray on in my other trucks, this is perfect for my use case.
https://www.weathertech.com/ford/2023/f-150-lightning/impactliner/
Ford F-150 Lightning Swing out fender box 20240131_092250
Ford F-150 Lightning Swing out fender box 20240131_092458
Smokewagun
Bob
N. Illinois
FYI, both of my box brackets are installed OVER a full BedRug, and I have no issues. I never cut out the side rug, just cut slots for the screws to pass through.
dww
San Antonio, TX
F150L, Tesla 3P, YP
Thanks for the wright up! It got me off the fence. I added the driver’s last week and passenger this week. I used a C clamp to bend the bracket so the holes lined up. I also added some additional tie down points to make up for losing the boxlink attachment. I reversed the hinges so the top opens out when accessing from the side. I doubt I’ll ever swing them unless I need to remove them. Removing the tail light was definitely the most nerve
wracking after recently finding out how much they cost.
Ford F-150 Lightning Swing out fender box IMG_3920
Ford F-150 Lightning Swing out fender box IMG_3915
Ford F-150 Lightning Swing out fender box IMG_3913
Ford F-150 Lightning Swing out fender box IMG_3907
Ford F-150 Lightning Swing out fender box IMG_3901
Reactions: JRT
Smokewagun
Bob
N. Illinois
Why did you lose the box link? Mine are still fully intact with both boxes. I think you were misguided, or installed something incorrectly if they don’t still function with the boxes. There’s a lot more tie area on the link than the rings you installed.
JRT
JRT
Huntsville, AL
Lightning
That is great, I wish I thought if using a c-clamp!
