Water Leaking Through Sunroof Controls
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
Same issue of clogged drains happens with convertibles. My Boxster is prone to this issue. I purchased a trombone cleaner brush which does the trick of clearing blockages, and you get to answer the question "why do you have a trombone cleaner?"
As a music teacher, I approve of this! A trombone cleaner is likely too big (the brush ends), but a trombone mouthpiece cleaner may work at the entrance of the drain tubes.
https://www.sweetwater.com/store/detail/YAC1078P--yamaha-trombone-cleaning-rod-large
MichaelCA
Furthermore, I re angled the truck and poured another, entire LITER OF WATER into each respective drain area, and just as you suspected — it drained fine.
Recommendation from a guy on the internet: If you’re expecting a heavy rain, do not park on flat surface.
Looks like water is damaging the glue too on the headliner. I’ll take a look at mine later today to help compare.
