XLT OEM Bed Lights Install
Blochead21
PA
Black 22 XLT 311pkg
My XLT didn’t come with bed lights which is ridiculous so I decided to research and install them myself. I know I could tap in with a cheap led light strip but I like oem even if it costs more.
I bought the below parts through tasca which was the cheapest I could find.
Ford F-150 Lightning XLT OEM Bed Lights Install EBD71E28-1768-48FA-AA4F-7F38D197679E
I pried the bed light covers off and fed the wiring in and down the side of the bed. You can use a screwdriver or trim removal tool. You can reach your hand in to feed the lamp switch and led in the correct spots.
Ford F-150 Lightning XLT OEM Bed Lights Install 34C6558E-2B2C-4D86-A9B1-100F04AE527E
Ford F-150 Lightning XLT OEM Bed Lights Install 24E5F0C5-A5E3-4C96-8932-1AFC1173F9C3
Ford F-150 Lightning XLT OEM Bed Lights Install 26A4E2DB-16C5-4143-89F3-5B7283AE0EE1
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_5291
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_5292
Once underneath you’ll see a dummy plug end on each side of the bumper. These will also need to be removed.
Driver Side
Ford F-150 Lightning XLT OEM Bed Lights Install A095DA7F-B5E9-4CE4-9D65-4762F57DB647
Passenger Side
Ford F-150 Lightning XLT OEM Bed Lights Install 75743125-FDE5-43A4-A701-F9CB7351F557
Once removed the plugs look like this.
Ford F-150 Lightning XLT OEM Bed Lights Install A94DFDF6-A9B6-4809-9F82-7BAC2087FD1C
Ford F-150 Lightning XLT OEM Bed Lights Install 92C0C283-DA49-4E4B-8B08-3FE936C8A109
Connect both sets of plugs into their respective mating plugs. There is one location to push the wiring Christmas tree in on the driver side and two on the passenger side.
Ford F-150 Lightning XLT OEM Bed Lights Install 8F9A1215-B314-4B4E-8648-466BE699D6C7
Ford F-150 Lightning XLT OEM Bed Lights Install 4A68D100-3D2A-4AB4-8A8B-E413486F6918
Ford F-150 Lightning XLT OEM Bed Lights Install BC12C7FC-3F44-4CF6-B62A-E6AB3644DDED
Once assembled you’ll need to open up Forscan and go into the BdyCM module, not the as built, and enable the below options.
Ford F-150 Lightning XLT OEM Bed Lights Install 390C17F6-4206-44CE-8143-12004717730D
Ford F-150 Lightning XLT OEM Bed Lights Install F875CC73-C59D-45D1-B2AE-D5D0EF7CBE64
Once enabled you now have working bed lights. :) Enjoy!
Ford F-150 Lightning XLT OEM Bed Lights Install B763EDB5-BD8C-44E5-8B02-9A4AAC564178
Ford F-150 Lightning XLT OEM Bed Lights Install 4EC6C518-3629-4E10-87BE-8A98BF1B6A37
wighty
NY
Are those OEM lamps LED?
Blochead21
PA
Black 22 XLT 311pkg
Yes they are. They are the same lights in the frunk.
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
Any idea if the Pro will have the same wiring available? Haven’t taken delivery of mine yet.
I really appreciate the write up and photos. Thanks!
Coming from a 2009 F-150 XLT, so not familiar with bed lights. When do they come on? Assuming some automatic times and also a manual switch as well??
Blochead21
PA
Black 22 XLT 311pkg
I have no idea about the pro as I haven’t seen one. And at least for my XLT without zone lighting they only come on when I push the switch.
laselvasurf
Phil
Santa Cruz CA
I just ordered everything you listed for my XLT with zone lighting, it'll be interesting to see if it shows up in the menu after enabling it in Forscan.
jimfigler
Orchard park, NY
Just an FYI on doing this mod. You can save some money by purchasing the LED lights on Amazon. The wiring and switch you’ll still need to buy from a Ford parts dealer. If you want to stick with all genuine Ford parts no problem but you get 2 for the price of one on Amazon. It’s just a choice if you want. LED Truck Bed Lights Compatible w/ 15-20 F150, 17-21 Rap'tor F250 F350 F450 Super Duty Pickup Truck, 6000K 40-SMD Led Bright White Bed Light Kit Rear Cargo Area Lamp OEM Replacement https://a.co/d/3167YKD
wighty
NY
I saw that as well, my only hesitation would be whether the tint truly matches or not. It would be really annoying (to me at least) if the color temps were slightly different compared to OEM/the rest of the truck.
Also, so it is easier for others, here are the links to the site in the OP:
Wire Assembly Jumper: ML3Z-14A411-F
(https://www.tascaparts.com/oem-parts/ford-wire-assembly-jumper-ml3z14a411f)
Wire Assembly Jumper: ML3Z-14A411-D
(https://www.tascaparts.com/oem-parts/ford-wire-assembly-jumper-ml3z14a411d)
Lamp Switch: FL3Z-9C888-B
(https://www.tascaparts.com/oem-parts/ford-lamp-switch-fl3z9c888b)
Cargo Lamp: JL3Z-13A756-A
(https://www.tascaparts.com/oem-parts/ford-cargo-lamp-jl3z13a756a)
3rdgenfan
Geoff
Delaware
Cybersecurity
Ordered everything yesterday to do this, OBDLink EX dongle arrived same day from amazon. Tasca's standard shipping is apparently hand delivered by foot looking at their estimated delivery dates lol.
jimfigler
Orchard park, NY
Or buy the color changing lights and be crazy
