Peter P
- First Name
- Peter
- Jan 8, 2020
- Fort Lauderdale
- 2019 Ranger XLT
Better than the officially published 150kW charging rate.
This is a poor "charging" video.
They plug it in, look at charging screen for 15 seconds when they were connected for 3 minutes.. then precede not to talk about charging or look at the screen again...
Just a click bait video.
It's always going to spike @ a specific % when you plug in it, then it will level off... You really just want to see what the level off speed is... Not whatever it did for the first 3 minutes.
I'll be doing that as soon as I get mine I will have a LOT of deep dive charging analysis.It would be great if they plotted kW vs time from very low to max SOC.
Looking forward to it. Hopefully you can spend a minute or so on the standard range theoretical curve data from ford. Also if you can get the technical reason from ford why the charging speed is less. Us standard range folks feel left out sometimesI'll be doing that as soon as I get mine I will have a LOT of deep dive charging analysis.
Thanks for the tremendous information I've gotten watching you videos.I'll be doing that as soon as I get mine I will have a LOT of deep dive charging analysis.
Definitely want to see this. 350kw are virtually non-extistent in New England.Thanks for the tremendous information I've gotten watching you videos.
Could you compare EA 150kW pedestals with EA 350 kW pedestals when charging Lightning? It would be interesting to know if the extra ~20kW is real, Memorex, or if it makes a difference across the charging curve. (The 800V folks are going to hate the competition for the 350s if it doesn't matter.)
Absolutely. I'll do 0% to 100% chargecrecordings on both 150 kW and 350 kW stations and compare the results. There really won't be much difference....Thanks for the tremendous information I've gotten watching you videos.
Yup - charge curve testing tonight for me@OutofSpecKyle I believe has one as well and a new Rivian to give comparisons. I want to see them both towing a large camper and see who does it best. They'll have a lot of good data on out of spec as well
