TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
So what should you do if you ran IPMA and PSCM and everything seemed to run fine (after 5 hours) but haven’t cleared from FDRS? Don’t really want to do Network Scan/Test. Just drive it and check again later? Or is this something that will stay populated like the GSM module update in FDRS
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Check for DTCs and clear them. If they don’t return, leave it alone and check again later to see if the updates are removed from FDRS. That’s all I’d do right now until more is known about these updates.
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Alrighty so I’m in AZ where the major freeways are definitely mapped for blue cruise. Drove the truck and used cruise. Dash said bluecruise enabled be prepared to take control. However it didn’t go full bluecruise just normal so I think I’ve still got some waiting. Like the truck knows it has it but maybe Ford hasn’t enabled?
TJSparky
WA
I don't show any DTC's and don't really want to run a scan with the VX Nano. However, the PSCM and the IPMA still show as available to Run like GSM. These still show when logging into FDRS without the VX Nano connected.
I'm not going to update it again. Just going to leave it alone and if things change in FDRS.
JEB
Northern Illinois
Makes sense. You probably aren’t supposed to have BC yet because you weren’t in the first wave scheduled to get 2.5.1. You stole it by updating it yourself—something Ford probably didn’t plan for. But Ford still needs to flip a switch on their side to activate you. It’s like other connected services. You might have all the necessary hardware and software but it still doesn’t work because you need to subscribe before they turn it on.
JEB
Northern Illinois
I’d stop and wait for more developments.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Almost sounds like FDRS let's you get to the equivalent of PowerUp 2.5.1, and you need to get to 2.5.2 for full BlueCruise functionality. Maybe in a few days it'll be available?
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
This is such a stupid rollout stagegy.
I tested mine and the BlueCruise On box showed up in the IPC, but not hands-free!
We still require the final update for GWM which is Power-Up 2.5.2 that must tell the cloud that we are authorized and activate the feature.
DW2020
Doug
2011 F-150 Platinum 6.2
I agree, looks to me like what is available in FDRS today are the modules that updated with 2.5.1. I'm thinking of ignoring the DTC in the IMPA that cropped up - it relates to network communication with the GWM....and knowing a GWM update (should) show up in FDRS later.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I finally have time to run the updates on CCM, CMR, IPMA, & PSCM but reading through yalls comments I wonder if I should just wait a little longer or push ahead? Decide my fate!
On another note I'm on Sync 22028, Revision 358. I've said it before but I'll say it again, thanks to everyone in this thread for helping me out. It was just a month ago I was stuck on OTA 1.7.1!
Kanuck
Don
Manitoba
2021 Super Cab Carbonized Grey 3.5 EC 302A 6.5 Box
Electrician, Retired
Hi.... would someone be able to run my VIN and see what updates I need. I received 2.3.0 on March 1st. 1FTFX1E81MKE01710
Thank you in advance
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
Yes, this helps. Sounds like the dataset has split purposes—part of it is for module restoration, part of it is for reporting/administrative purposes. The same part of the dataset is not used for both purposes and the Nano corrupts only the administrative portion. I understand now. Thanks.
Certainly makes makes the dataset safer to use but really adds to the overhead.
RapidRedRick
Rick
Northern Virginia
I have the original backup .abt file for the DSM I created in Fosrcan, but when I am in Forscan and attempt to load the file it says there is an error opening the file.. I am able to open this file in Notepad so I don't think it is corrupt. Is this the file I need to load to the DSM or am I missing something?
