JEB
Northern Illinois
2021 F-150 Lariat Powerboost
My vehicle is not Blue Cruise capable so I am not sure if that affects different updates\modules available.
I don’t have BC either. We’re all getting the same updates from what I can tell with the exception of the driver spycam module, which non-BC equipped trucks don’t have.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Can any one please take a screenshot of what updates available to my vehicle.
1FTFW1E51MFC37912
Skier167
Nate
Ohio
2016 f150
I’ve tried running the Icm update a few times and all goes well till the module configuration and it keeps saying it failed. Even after multiple retry’s I can’t get past it. Did I miss something in the posts to avoid this?
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Has anyone actually gotten their BlueCruise to start working in the last 48 hours? There are so many posts it's hard to tell, but it seems like it's just troubleshooting lately. I'm wondering if Ford has stopped sending the last set of APIM/GTWY out that we need.
lcm?
rpeterslll
Rob
Livonia, MI
2018 F150 Lariat FX4 Sport
IT Professional
Game changer??? If I had to guess, which I do, I believe this procedure will allow the Stuck OTA 1.7.1 update to clear allowing the APIM to update via USB immediately rather than have to wait that extended period of time.
Skier167
Nate
Ohio
2016 f150
My doc tells you how to kick off a CAN Bus update but, be prepared to be there for a bit.
That’s what I was afraid of. The usb install is successful and when I go back into Fdrs and it wants reconfigure the module is where I’m getting the error that it can’t connect.
JEB
Northern Illinois
@Skier167. Before you do that, start up your truck and check to see if your instrument cluster comes up normally. If all looks good, shut back down and go into FDRS and do a new network scan. See if you have any DTCs. If all you’re getting is U2100–Failure to configure, try a PMI selecting new module and see if that clears you up. Then do another network scan and see if the IPC update is still there.
Problems with the IPC have come up before, particularly failure to configure. Some of that discussion, and the fixes, can be found beginning here: https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/post-181745
antho
Anthony
Houston, Texas
2021 801A Raptor
I noticed that under the Multi modules this am. Thanks for the doc.
ksimon123451
Kelly
21 F150 Lariat
Systems Administrator
Is this the fix for APIM not updating with USB?? OMG
Skier167
Nate
Ohio
2016 f150
Instrument cluster looks good. No DTC’s in IPC. only DTC I have is U2101 in the IPMA which I’m figuring is related to my pre-collision assist error on the cluster screen.
