Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
@Jesse-Infotainment or @iceman77, APIM Lines - DID F12A, and DID F0E8, only shows ML3T- and nothing else. Is this normal? This was the OTA in February that put me to 21281 rev244. I am one of the ones stuck with the 8" cluster and unable to update to the latest APIM software.
APIM - SYNC Module
- No DTCs Detected
- DID DE05 - 1A681A6838A4
- DID F1D0 - 28385C0D963B
- DID F113 - MU5T-14G670-PNN
- DID F190 - 1FTFW1E52MKE
- DID F12C - NL1T-14F180-FB
- DID DE01 - 0616420A02020000D800A800000000
- DID F124 - MU5T-14G677-ABA
- DID F18C - FUBCH21130051840
- DID DE08 - 63174228FAC06E57020D004000040793400250E00005000000
- DID 8060 - MU5T-14H008-BLJ MU5T-14H008-BKJ MU5T-14H008-BJJ MU5T-14H008-BCJ MU5T-14H008-BFJ MU5T-14H008-BEJ MU5T-14H008-BBJ MU5T-14H008-BGJ MU5T-14H008-BDJ MU5T-14H008-BAJ MU5T-14H008-BHJ MU5T-14H008-BMJ MU5T-14H009-FAG MU5T-14H009-FBG MU5T-14H009-FCG MU5T-14H212-PF
- DID 8068 - MU5T-14H236-LA
- DID EEFE - MU5T-14H233-AD
- DID F129 - ML3T-18K811-AA
- DID F166 - 18022202
- DID F12A - ML3T-
- DID D027 - MU5T-14H234-BD
- DID DE04 - 2186000000000300E5D84BE7000000
- DID D040 - 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
- DID EEFF - MU5T-14H235-CN
- DID F142 - MLAF12317H
- DID 8061 - MU5T-14H212-RF MU5T-14H212-SF MU5T-14H212-TF MU5T-14H212-UF MU5T-14H212-VF MU5T-14H212-XF MU5T-14H276-CF MU5T-14H276-EF MU5T-14H213-LAF MU5T-14H214-NF MU5T-14H211-CB
- DID D705 - 00000000
- DID 8033 - MU5T-14G682-JK
- DID DE07 - C0000002000000000000
- DID DE00 - 20010802BD2300C22919504D21E51E02E4000040
- DID F0E8 - ML3T-
- DID D704 - 0316EA01
- DID F12B - ML3T-18B955-AF
- DID DE03 - 0524000000
- DID F16B - MU5T-14J003-AF
- DID F143 - 20210326195256
- DID F111 - MU5T-14G681-KF
- DID DE06 - 20003300000000000075305656A300C8
- DID F188 - MU5T-14G676-EG
- DID F0E9 - NL1T-14D358-FB
- DID DA01 - DSMU5T-14G670-EG
- DID F17F - 1SN174PD
- DID F110 - DSMU5T-14G670-EG
- DID DE09 - 0000000000000000000000000000000000000023194F604F60
- DID F10A - MU5T-14G680-AA
- DID DE02 - 55530203030B00140E010000000000
- DID EEFA - 020FC00E828F823D
- DID F15F - 19060701700274020000
- DID F163 - 04
- DID F144 - G1RCVDCN
- DID F1D1 - 28385C0D963C
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
Some moderately unrelated items:
- the freezing when using the bed and tailgate cameras in motion, i've not been able to reproduce the freezing when switching between the two. i've really been trying! haha
- all of the updates seems to fix the issue with the "trailer disconnected" alarm happening on certain trailers with LED lights.
Whoskyle
Kyle
AZ
2021 F-150 XLT
Quick update for all, when trying to perform the TSB, I kept getting this error. Trying to figure out what is causing it. Jesse said Gateway, but no idea what to do next
Ford F-150 Lightning ECU module programming guide using FDRS B0E38EC7-8A29-434C-9479-8221910537B7
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Given the cost of the USB-A to USB-A cable and the USB Ethernet adapter, I think I may just buy them at some point to have them on-hand should I need them in the future. Could be $20 now to save me days of headaches down the road.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Nope, this is just a “fastboot” procedure to kick your APIM out of the failed 1.7.1 OTA purgatory. Once done, you need to proceed normally with FDRS and Mongoose cable to update your APIM. If you have a USB flash drive with your APIM update ready, you don’t need FDRS to kick off your update. Just insert your USB flash drive while your ignition is KOER, it should kick of within few minutes
It's a little more involved than just kicking it out of that state. I did this back in December when this procedure first popped up briefly in FRDS.
It installs a base image on the APIM and then you use the USB to install the other items like voice, maps, etc.
Hopefully, they ironed out the issues because mine didn't install the Map application because Ford thought it was already updated so I was screwed and had to send my APIM to Jesse :)
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Dear can any one check my vin and see if I still have an update.
I just received a sms from dealer that my car is READY to pick up.
1FTFW1E51MFC37912
christophers
Christopher
Austin, TX
yeah, this is (to me) the scariest outcome of all this: disrupting a data store or application that can't just be dropped back on via FDRS.
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
Try logging into FDRS with the flash drive in the USB port and running a self test on the APIM.
Tried this a couple times to no avail. Updated everything else except APIM. Adapters on order for TSB.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Oh that's a big one! I haven't driven my truck with my TT since I did all my updates but I'm looking forward to not getting that error message!
christophers
Christopher
Austin, TX
yeah, that is honestly why i went down this path. i dont really care about BC, i just wanted the alarm to stop going off.
