sotek2345
- First Name
- Tom
- Jun 7, 2021
- Upstate NY
- 2022 Lightning Lariat ER, 2021 Mach-e GT
- Occupation
- Engineering Manager
Our Mach-e does take a bit longer to heat up if it is cold soaked, but it is still MUCH MUCH faster than and ICE vehicle I have ever known. With my F150 I am usually at work before I start getting any hot air out of the vents (shorter drive, no idling before leaving).I've seen about an additional 10-15% range reduction if my Mach E is parked outside overnight and is cold-soaked vs. parked in a garage heated to 50F. The biggest difference I notice is that (if I haven't remote started or set a departure time) it takes a quite a bit longer for the cabin to get warm, especially if it is really cold (-F) outside.
After a year, I have no worries about charging indoors even though the garage is directly below the master bedroom. If that concerns you, you might want to set your charging to occur during the hours you are awake. That way you can watch the house burn down rather sleep thru it ?.
