Power Up-3.4
RainorshinePNW
Here's a new one- after 3.4 my Nav measurements are in metric, and yet my efficiency is still in imperial... I can't figure out (yet) how to fix it. When I go into Settings, it shows that I do still have miles selected as the measurement ?
Ford F-150 Lightning Power Up-3.4 PXL_20220819_051329998~2
F150ROD
U.S. Navy Retired
The 3.4.0 update was to the following modules:
BECM (Battery Energy Control Module
PCM (Powertrain Control Module)
SOBDMB ( SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE B)
SOBDMC (SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE C)
Explains why vehicle inhibit was required!
Can this be stickied to the OP?
This pretty confirms the changes to 1PD along with others who have experienced the same change.
RainorshinePNW
In settings, change the units of measure to metric, and then back to imperial.
Worked for me; YMMV.
Did yours change with this update before, or did you just have to do that previously with other updates? Thanks for the suggestion, will try that
duncanmaio
Duncan
Norwood, MA
Just once, earlier this week. I haven't been tracking the updates all that closely.
This morning, the back seat warning was turned back on.
davidf01
CT
F-150 lightning
I'm still on Powerup 3.1 I don't have a auto update slider button and can't seem to get any updates. Is there something I need to do to start getting updates? I just picked up my lightning 2 days ago.
Thanks
V8BoatBuilder
Aaron
New Jersey
22 Lightning
Ford F-150 Lightning Power Up-3.4 IMG_7101
Mine turned into a Mach-e too!
Fortunately/unfortunately it changed back to a Lightning on the next restart.
  • Haha
data003
Maine
2022 F-150 Lightning Lariat ER (Totaled), 2025 F-150 Lightning Flash ER
Thanks
Connect the truck to your wifi
I thought these would roll out quicker to the fleet. The only update my truck has received was 3.1 a couple of weeks ago while it was in the shop. I think there are at least 2 more since. I'm connected to Wifi, have a schedule set up and force check a couple of times a day.
I'm used to waiting forever sometimes from Tesla, but thought Ford might be quicker for these new trucks. I guess they roll to a few and then gather information to know if it is working and then tweak if necessary. However I thought that would be what the early access program would be for.
davidf01
CT
F-150 lightning
Yes I connected my truck to my wifi. I also don't have a auto update button/slider anywhere and can't schedule an update.
data003
Maine
Weird, mine updated twice in the first 24 hours once I connected it to wifi.
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Just curious, how many miles do you have. I’m starting to wonder if somehow it’s mileage based?‍♂ I’m over 3k miles already.
emmelj
Jerry
DFW
2022 Lightning, 2018 Tesla M3
Got mine last night. Now my f150 icon in the upper left corner is gone and a Mach-e is in its place.
Moderator inserts specifications to first post on this topic for quick reference.
same exact thing. it did disappear after a restart of truck
I’ve had the truck since July 15. It was in the shop for almost two weeks (which is where it was when it got the first update). I’ve got about 900 miles on it.
Ford Motor Company
Official Ford Account
F-150 Lightning
After the latest powertrain “Over The Air” update you will have your 1 Pedal drive setting reset to the factory setting, which is off. If you are a 1 Pedal user please check to make sure your vehicle is in 1 Pedal mode by looking for the ICON in the cluster. This will be corrected in the next powertrain OTA update to retain your settings.
