I Confirmed ProPower is a Pure Sine Wave Inverter - And the Power is CLEAN!
V8BoatBuilder
Aaron
New Jersey
22 Lightning
The power went out at my shop this afternoon in the middle of a project, so rather than fire up a gas genny, I used Pro Power, which worked great. Curiosity got the best of me, so I hooked up an oscilloscope to see if the inverter was pure sine wave or modified sine wave, and then tested utility power (JCP&L) which came back on.
The Test:
Ford F-150 Lightning I Confirmed ProPower is a Pure Sine Wave Inverter - And the Power is CLEAN! IMG_7991
Truck Power:
Ford F-150 Lightning I Confirmed ProPower is a Pure Sine Wave Inverter - And the Power is CLEAN! F150Lightning20221019-0001_01
Utility Power:
Ford F-150 Lightning I Confirmed ProPower is a Pure Sine Wave Inverter - And the Power is CLEAN! WallVoltage20221019-0001_01
The graphs are slightly different time scales (sorry!) which is why the waveforms look a bit different, but the power coming from the truck is CLEAN! Thanks Ford - nice job!
Maxx
great post. This was a big question for me. Thanks.
HaroldCal
Harold
Las Vegas, NV
Thank you for confirming this. As an IT guy, this was a concern for me. Want to keep my gadgetry happy.
Now we need to find out of the inverter in the SunRun Home Integration System is also Pure Sine Wave or Modified.
lightspeed
2023 Lightning Lariat ER
Sorry to ask, but did you try all the outlets? Front-trunk, in-cab, and bed outlets? I would expect them to all be the same, but they are on different inverters are they not?
V8BoatBuilder
V8BoatBuilder
Aaron
New Jersey
22 Lightning
This was just the bed outlet, with almost no load.
vandy1981
Tennessee
Plumber
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Great news!
I was expecting a high frequency stepped sine wave but this looks so much cleaner!
No worries running a PC desktop off it!
wighty
NY
Thanks for the confirmation. I assumed it was a good pure sine wave given I believe some power tools would require pure sine to work properly (not sure where I read that, though).
The Test:
Truck Power:
Utility Power:
It is hard to tell for sure just how clean the bed output is from your image of the output.
Some modified sine waves are "cleaner" than others but not pure sinusoidal, and just dirty enough to cause sensitive equipment to malfunction.
Some other posts have noted a difference in the output from the front inverter and the bed inverter in trucks with two inverters (9.6kW ProPower) and found that the bed outlets cause malfunctions in things sensitive to "dirty" power (modified sinusoidal), like electric blankets.
Does your truck have the 9.6kW ProPower which uses 2 inverters?
EVpower
Steve
Northern California
2023 F-150 Lightning Lariat, Bronco II
Electrical Engineer
When I took delivery on my Lightning I checked the bed outlet waveform with an oscilloscope. My calibrated eye rated the THD at less than one percent.
I’ve followed the reports of problems some have had with PPOB. I suspect the issues are caused by commutation noise from the triacs in the load affecting the PPOB ground fault protection.
So far I have not found a load for testing which will trip GF protection in my Lightning other than a GFCI tester.
We have used the Lightning for home backup power for about 50 hours of utility outages this year. PPOB has kept the lights and all the appliances on.
Steve
V8BoatBuilder
V8BoatBuilder
Aaron
New Jersey
22 Lightning
Yes - Mine is a 22 Lariat with the dual inverters.
