FordPass not responding
davidf01
CT
F-150 lightning
Anyone else getting "FordPass not responding" when trying to set departure time on the app. I'm on a android phone.
BennyTheBeaver
My FordPass stopped responding yesterday around noon.
Since then I've also noticed:
- Zone Lighting (on truck screen) won't toggle on
- If I test my frunk outlets in ProPower I get a ground fault
- Automatic updates (on truck screen) went to off and won't let me toggle back on
Not sure which of these are related but I do have a ticket in with Ford and an Engineer is supposed to get back to me in 3-5 days.
Thanks to forum members help I was also able to determine the I have no DTC's in the cloud and no Pending updates.
I've also tried resetting FordPass (in truck), Factory Reset, and uninstalled/reinstalled FordPass all to no avail.
Works for me, but it took about 50 seconds to post and acknowledge.
When FP is wonky, I force stop the app, clear the temp cache and restart, usually responds better, though changing charging and departure schemes often result in long delays before adjustment posts
luebri
Neenah, WI
My truck has not communicated with Fordpass for 22 hours now. It will no longer detect my wifi network either. I was told by chat to toggle connected services, but I have no ability to do this that I can see.
Capertrj
Ricky
Maine
2010 F150
I noticed mine when I click Smart Hitch or onboard scales it says not operational please visit your dealer for service.
davidf01
CT
F-150 lightning
Connected services is on the truck screen someplace I can't remember exactly where under settings I think.
luebri
Neenah, WI
I know where it is but there’s no toggle button, at least not for me
BennyTheBeaver
To detect a wifi network I needed to shut off wifi on my phone (easiest way to disconnect from wireless Android Auto). The truck's uses its wifi connection to connect wirelessly to Android Auto (and CarPlay I assume).
That didn't fix anything for me, but it did allow the truck to reconnect to my wifi.
When I click on Connected Services in settings, it tells me it's currently unavailable. Was working fine 48 hours ago.
BennyTheBeaver
I fixed my connectivity with FordPass issue. I pulled the negative leads from the 12v battery, hit the start button on the truck (old habit of draining phantom charges), and reconnected the negative terminal.
Only issue was my frunk got stuck up, had to gently manually shut it, then it worked fine.
Hopefully these issues in the future don't require a full reset via battery terminal. I shouldn't have to install a quick terminal disconnect for THESE reasons. ?
@Ford Motor Company
HaroldCal
Harold
Las Vegas, NV
3x F150L MY2023 (1 Plat, 2 Lariat)
Yes, this exact thing started a few days ago for me. Also Android, if it matters.
SCC17605
Kansas City, Missouri
67 Camaro, 02 F150
@Ford Motor Company
I had this exact same issue. No connection since 12/11. Ford said it would need a trip to the dealer. Not really wanting to bring a truck with 800 miles on it to a dealer to be torn apart but your trick seemed to fix it, for now at least so thank you. This shouldn’t be such a widespread issue on a truck that’s been out for almost a year.
IH905
Isaac
Ontario, Canada
2020 Lincoln Nav, Lightning Platinum-On order
Business Owner
I'm having the same problem when I noticed my location hadn't been updated on my Ford Pass app. When I check the connectivity setting on the truck, it says setting not available. I'll try the battery disconnect and see if that works.
Ford F-150 Lightning FordPass not responding IMG_1001(2)
BennyTheBeaver
FYI, I also made sure the truck was unplugged.
davidf01
CT
F-150 lightning
BennyTheBeaver
Did you try holding the volume down and next track buttons till the screen resets?
Yes mulitple times, and a FordPass Reset, and a Factory reset.
