Adding SecuriCode to Pro?
BennyTheBeaver
I also need this for surfing and just ordered one. I found this install video. I'll let you know how it goes.
That one replicates a keyfob and it protrudes out the side, FYI.
I will be installing the Securicode keypad. I found the correct trim piece but the keypad is out of stock everywhere I've looked and I'm not willing to pay outrageous prices on eBay.
viennaxmas
Sarah
Vienna, VA
One option would be to order the Pro trim piece without the cut-out (or just fill in the cut out in the trim piece you have), and then wrap the trims so they all match. Here is a video of someone doing a wrap on that trim:
If you decide to do it, would love pictures of the inside of your door and the wire harness. A bunch of us are trying to figure out if we can wire in the intelligent access handles on the Pro and low XLT trim.
In fact, I'm in the area and will happily offer you a helping hand and take the photos!
I found videos where people are replacing the keypad. They also nicely show the wiring inside the door. https://www.youtube.com/watch?v=XHyoHYLKbZI. After looking at the video I decided to not attempt this...
jazzmanmonty
Lincoln Corsair
self employeed
I too reluctantly declined adding it for the same reasons. If I were to invest that kind of effort into a petty upgrade, it'd be to replace the door handles with the button to unlock or whatever the key fob sensing technology is called that knows when you're close
Mcalc55
F1504855
2022 Lightning Pro
wait..is this an option??
jazzmanmonty
Lincoln Corsair
self employeed
i'm stil researching this. My dealer does aftermarket upgrades in house, so i'm gonna swing by and ask. There was also a post on this forum of an upgrade that allowed you to add remote start to oem keyfob which i am probably gonna do.
jimfigler
Orchard park, NY
I removed the door panel today and the connection is there. I wanted to make sure the connection was there before I ordered the trim piece with the cutout. I misplaced my code card. I assume the dealer can get another with my vin. I did temporarily hook the keypad up. It did light up. I tried pushing the top and bottom button to lock it but it did nothing, but the door was open. i couldn’t close the door cause the door panel half on with door latch and lock cable still attached. Can anyone confirm that we need to charge stuff in forscan. I did find a setting “keypad” which I enabled.
Blochead21
PA
Black 22 XLT 311pkg
Should be 7/8 and 9/0 to lock
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
I have the matte cutout panel on order from tasca. Going to cut my current one, but wanted a pre cut one on standby I’m case I screw it up. As far as ForScan, these photos attached are what I have found so far!
I HAVE to have this mod, so just waiting on the trim panel. My 2009 F150 I used EVERY TIME. Keys never left the truck….never misplaced my keys in 14 years…haha
Ford F-150 Lightning Adding SecuriCode to Pro? 4CE79278-CE73-441B-85C4-7FEEE88F4256
Ford F-150 Lightning Adding SecuriCode to Pro? 24C65F65-7F6E-4C87-B052-0CFEC268EAE3
Ford F-150 Lightning Adding SecuriCode to Pro? 18926766-7AB9-4F5B-B34F-96A317F99A55
jallen
jimfigler
Orchard park, NY
I found a two key procedure to get my code. I also found two settings, one in BCM that lists keypad. When I enabled it updated 726-31-01 xxxx xx01 xx—. I also found a keypad in APIM and I enabled that. It updated 7D0-01-02 xxxx x2xx xx—.
both of these I had written on scrap paper I had written down awhile ago.
Ford F-150 Lightning Adding SecuriCode to Pro? DC1E4C3D-33AA-4A6E-B6F5-E525FCFA66F0
jallen
Success! I pulled the door panel off again. I hooked up the keypad. i locked the door with the power lock button on door and entered my code and the driver door unlocked
Good deal!!
I have my pre cut door trim and all of the bed lights and wires ordered from tasca. Already have the door code assembly. They said some of the items are special order or delayed. I might give them a call tomorrow to see if it’s the door trim or not.
jimfigler
Orchard park, NY
Btw I the keypad I got was from amazon. I know some have had trouble getting them. I just ordered the trim piece from tasca
Shady
2021 F150xlt
