The Ford Lightning Miscellaneous Question and Answer Thread
BennyTheBeaver
That's what I've been saying in this thread but if you don't know what I'm saying here, then I digress. :cool:
Kind of. You're asking for a forum within a forum. I mean, do what you want, I'm not the forum police. I'm on here to learn and help people. A single chaotic thread with random questions feels less organized and harder to find answer for, that's all.
Not the forum police here either, but as a moderator on a different forum for the last 5 years - we push hard to have a single topic per thread. There were 5 to 6 moderators and daily we merged threads, moved threads and moved off topic posts to an off topic forum. It's a lot of work, but it made finding information much easier.
My comment is not negative toward the forum here either - don't take it that way. It runs pretty good around here. My comment is that it can be a lot of work to keep one running real well all the time.
Lightning Rod
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I completely understand and agree that moderating and maintaining a message board can be hectic. I love this board and I get great info from it, but there are times that a search does not quite answer some questions, fully. Please feel free to delete this if not much good can come of this thread. Thanks to all members for your input. :)
MickeyAO
Mickey
San Antonio Tx
I would think if a thread doesn't quite answer your question, maybe post your question in that thread instead of starting a new, similar thread.
Lightning Rod
Lightning Rod
North Coast
I think it's fine to have threads like this.
I don't look at this thread like "starting a new thread". I look at it like the title says... Miscellaneous. Almost like the "What did you do to your Lightning Today" thread. It's not just one topic.
Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost
Can someone post pictures of under their dash, both drivers side and passengers? I see some people are missing the trim down there
Lightning Rod
Lightning Rod
North Coast
Are the 12 volt battery terminals easily accessible when opening frunk? Before I take delivery of my truck, I want to order a Vivair air compressor that connects by clipping to bat terminals. I hope there isn't a cover that I have to remove before connecting compressor.
Thanks.
ctuan13
Chuck
Pittsburgh, PA
Thanks.
There is a plastic cover in front of the 12V battery. It's not hard to remove, but it needs to be done correctly. I've even had dealer techs fail to do it correctly, break a tab off and have to give me a free replacement. The cover has to be pulled up, NOT towards you or else you will break the retention tabs on the back.
Lightning Rod
Lightning Rod
North Coast
Ok. Thank you for that info.
Amps
Bolt
+1 for @Crilly 's post above. You're swimming in copious amounts of 120V power with or without Pro Power Onboard. IMHO, no reason to needlessly pull power out of the small 12V battery that is so critical to the operation of the truck's systems.
Lightning Rod
Lightning Rod
North Coast
I have 120 volt plug in air compressor. That is far better than 12 volt. You can plug it in the frunk, cab, or the bed of the truck.
This makes perfect sense. Do you guys have any recommendations for a small portable 110v compressor that i could maybe store in the sub frunk? The Viair pump i have in mind is very powerful yet portable.
Thanks.
Jarratt
Jarratt
NM
Tundra. Tacoma, Model 3, Lariat Max Tow, lng range
Do you have a brand/Model # recommendation " Thanks
Lightning Rod
Lightning Rod
North Coast
Does anyone know about the B&O audio system? I thought I read somewhere that loading a thumb drive with mp3s and other audio formats would play on the audio system. Was I misinformed? :unsure:
You can and I did for a while - I actually loaded up some Flac files. I've got them on an SSD drive plugged into one of the ports by the phone charger. It became too frustrating as the truck couldn't keep them sorted. It would index and sort day 1, then a few days later they were totally in a different order.
Once you get the drive plugged in - hit the screen with the apps on it and it'll have a USB drive or the name of your drive may even appear - select that and you should be able to play them after it indexes what is on the drive.
