captcory
- First Name
- cory
- Sep 23, 2022
- sw florida
- '23 FORD Lightning PRO, honda pilot
here are the numbers for the standard range. if you charge to 90% it's actually 83%
If you charge to 85% it's actually 78%. If you wanted to charge to 80% actual then you would set it to 87% but as far as I can tell that is not possible. It only does increments of 5. So I'm leaving mine at 85% which is under the 80% actual and I'm comfortable with that.
