grantmethepower
Grant
LA, CA
2023 F-150 Lightning Pro
Has anyone gone ahead and attempted this like the ICE models by adding everything to a base model Pro without the tow tech pack yet? Still on my wish list just not confident enough to be the first.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Has anyone tried this on 2023 XLT Lightning?
If you have the 4 CCM wires from the IMPA to the passenger kick panel it's a very tried and true mod.
theblunden
NC
2023 F150 Lightning XLT
mikedroof
Oklahoma
Bronco (Reserved)
Hey there. I’m coming up short. I can’t get the CCM to show up after changing codes in FORscan. Any ideas?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Have you personally traced and even Ohm'd out all 4 CCM wires all the way to the IMPA? When I was doing this I made a long lead and had my brother physically probe each pin of the CCM connector while I did the connector at the IMPA through the dash side access standing at the drivers door with the IMPA connector unplugged.
mikedroof
Oklahoma
Bronco (Reserved)
That’s the plan this weekend and go from there. I appreciate everyone’s help.
mikedroof
Oklahoma
Bronco (Reserved)
alexose
Alex
Portland, Oregon
2019 Chevy Bolt
Several people (including myself) have had to force a write to the IPMA module before CCM would show up. Check out this post before you spend too much time taking your bumper apart :)
mikedroof
Oklahoma
Bronco (Reserved)
Thank you. I remember that post and tried to force it several times with no luck.
mikedroof
Oklahoma
Bronco (Reserved)
Got the wires ran. Checked that the CCM module was receiving power. All back together but darn thing still doesn’t recognize the CCM. Even after IPMA changes.
hringrose
Hunter
Concord, CA
2023 Ford Lightning Pro, 1965 Ford Mustang
Geotechnical Engineer
Did anyone have issues with the proximity sensors not alerting after this install? No errors but I don’t get the colors and beeps to let me know I am getting too close.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
You'll only get it from the driver's handle.
hringrose
Hunter
Concord, CA
So I was able to fix this by dropping my tailgate, going in reverse, and setting off the rear parking sensors. Once I went into drive, the front ones worked. Weird but hopefully useful knowledge in case anyone else experiences this.
