Leveling Kit -- 2.0" vs 2.5" vs 3.0"
FlatcoatFarm
Clark
Santa Cruz
2023 Lightning Lariat ER
Greetings. New 2023 Lariat ER owner, with a leveling kit question.
(Actually, it's my second Lightning in 6 months -- after purchasing the XLT SR in May, I loved it so much that I decided to sell my other ICE vehicle and make the Lightning my daily driver and only vehicle, and determined that I needed the ER battery and a few other creature comforts to confidently "pull the cord". Traded the XLT in for the Lariat. Love the Lightning, Ford has done a great job, IMO.)
Like others, my plan is to install a leveling kit, and replace the stock tires with a slightly larger, more aggressive AT tire (current thinking is the 285/65/20 Falken Rubitrek).
My question: I have seen posts on various leveling kits -- 2", 2.5", and even 3". Does anyone know which kit makes it perfectly level? I have no plans to pull a trailer (on any regular basis), and the loads in my bed will not be extreme.
Thanks in advance for any guidance.
Reactions: dww
WhipSticks
Stephen
Maine
2023 F150 Lightning
Scientist
I can't answer your question, but my first thought when considering a leveling kit had to do with the potential to throw off some of the electronic systems. For example, by raising the front end a few degrees you are changing the angle of the pedestrian and collision detection systems. Presumably, these have been optimized for the stock positioning. I also worry about the impact on Bluecruise performance. I have done absolutely no research on this, but it gave me pause enough to decide to forgo leveling in the short term. Back when we drove our own trucks manually, this was not a concern.
FlatcoatFarm
Clark
Santa Cruz
Those are valid concerns. Thankfully, everything that I have read based on others' experiences indicates that a leveling kit does not affect Blue Cruise.
Whammy Bar
2.9 inches takes it to perfectly level with no rake. All onboard systems work at intended with no adjustments. Only thing you need to adjust is the headlights down about 15 turns.
eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
look for 2.5-3.0 inches in the front.
Some scrap boards under your front tires can give you an idea of what it will look like before pulling the trigger.
FlatcoatFarm
Clark
Santa Cruz
Thanks, everyone. I pulled the trigger, and I'm having the 2.0" Ready Lift leveling kit and a set of 275/65/20 Falken Rubitreks installed on Tuesday. I'll send pics!
PAndaemonium
MY23 Ford Lightning XLT ER
You have photos? I love those rubies but hard to find. What size you go with and how did it affect range?
Oneand0
Mario
South Lake Tahoe
Digital Investigator
I’m in a 2022 Lariat and have Rough Country 3”. Taken it off road and helps me camping. I don’t know if it’s perfectly level, but close enough for me.
Ford F-150 Lightning Leveling Kit -- 2.0" vs 2.5" vs 3.0" IMG_6349
FlatcoatFarm
Clark
Santa Cruz
I went up to a Rubitrek LT275/65/20 size, and the 2.0" readylift leveling kit. Extremely happy with both. I really like the stance of the leveled truck with these tires. Smooth ride, tires run and wear straight, zero vibration in steering wheel at higher speeds. And love the road feel of the grippier rubber. I'm on some dirt and steep gravel roads each week, and love the confidence of the bite in the road. Just had the tires rotated, and experienced zero change to the feel of the truck, which is always a good sign to me that they are wearing evenly. There's a slight change in road noise over the OEM tires, but not a bothersome sound at all, to me.
I have over 8,000 miles on the truck. The first 3,000 on the OEM tires, and the last 5,000 on the Rubitreks. I got 2.2 miles/kWh on the OEM tires, and have gotten 1.8 miles/kWh with the Rubitreks. (Although, it also started getting into winter temps as I put the Rubitreks on, which I'm sure has also had some effect.) And zero impact (that I can tell) to BlueCruise -- which I use a lot.
Ford F-150 Lightning Leveling Kit -- 2.0" vs 2.5" vs 3.0" 1709480629430
Ford F-150 Lightning Leveling Kit -- 2.0" vs 2.5" vs 3.0" 1709480955586
joesrepsol
Joe
Rocklin, CA
2022 Ford Lightning Lariat
Solutions Engineer
Bluecruise works fine on my leveled Lightning too, but the auto driving/lane/sterring part? Still goes left, right, left, right like a drunk driver would. Still not fixed or updated from what I can tell.
Maybe it never worked great from the factory either? I put on level + wheels/tires right away. So I can't really say.
Truck looks great!
broteus7
Irvine, CA
2023 XLT ER Carbonized Gray Metallic
Is this easy to do? Would this need to be done regardless of how big or small the leveling kit is?
Whammy Bar
If you adjust the angle of your truck, you need to adjust your headlights. Or else.... you're that asshole blinding everyone.
If you can turn a screwdriver, you can adjust a headlight.
