JRT
- Jul 18, 2023
- Huntsville, AL
- Lightning
So this I not my 1st EV, I cut my teeth with 31k miles in a 2021 SR Mach-E and did several trips and know the wonders of reduced cold weather range very well. I was carrying my Mach-E and my 2014 Ram 1500 for those years because we just need a truck for family trips and moves, the ER 2023 XLT I have is perfect and even with the observed 20% winter range impact will still work well, if I plan and research. If I was a normal consumer I'd be very mislead based on the built in Nav right now, it is almost a safety issue when you consider potentially hazardous cold weather too.
So we have a trip from Huntsville AL to Flagler Beach FL this holiday coming. I've done plenty of planning and even bought the ABRP upgrade to try out. ABRP gave me a pretty good plan with my adjusted settings, I tweeked 2 stops for convenience and it had minimal impact. Basically 4 stops would be good, but I wanted to shorten stop times to not be 40 min plus charging so add 1 stop. This kept 3 stops well under 30 min and 2 just over 30 min. All EA stations with good Plugshare reviews and status. So should be a free trip with my credits.
For fun, since Ford EV specialists PM about my Lightning, to help me get ready, lol. I told them I'm pretty set but the entire Ford Pass app planner was terrible. They said oh no it is much improved, give it a try.... well I did. Planning on the phone isn't great, but it did give me 3 charging stops, and I added 1 that I wanted. So not really as well optimized vs ABRP but this was my experiment. I went to load the trip in my truck and it recalculated it to 2 charging stops! Given 50s outside this would never work and hopefully it would adjust and add charging stops.
I guess my useless point is if I set up a plan in the app, then why does the built in navigation go and replan it and remove the stops. That is madness in my opinion. I'll be running ABRP on this trip and have all the extra charge stations on my trip notes just in case.
