MPH display?
Crullbri
2023 Ford Lightning Lariat
Semi Retired, Part time Handyman
I have learned that my Lightning was made in Canada. My question is, i only have the option to see MPH/KPH displayed also right above it. When ever i charge to 100% for a trip, it goes to KPH even though i have the MPH/KPH option checked. My other options are only KPH. Is this what the American made trucks have, or it this something i have to live with since built in Canada? Thanks, Brian
All Lightnings are made in Dearborn, MI.
Are you saying your gauge cluster defaults to Metric?
Zoinks. You're stuck with a Canadian version.
There might be a way to change it completely but there may be physical changes required. The truck uses a different wireless provider in Canada.
I bet there's a Forscan fix.
Edit: I also bet a dealer could also change it.
Edit again: there's a "General" setting in the center screen called "Measurement Unit:" I bet this is the real answer.
Crullbri
Pioneer74, I guess it defaults to KIlos. does all other displays show both MPH and KPH?
Crullbri
Does everyone have the display of KM/H above their MPH?
The Weatherman
Dean
South Central KY
It’s either or. It’s changeable in the big screen.
I just checked my truck, 23 Lariat, you can select the mph speedo with kmh on top through the cluster but in the general settings on the 15" screen you can change it to straight miles and miles/kwh.
I'd be curious to know if you have any news or other non game apps on your entertainment screen. My truck does not have them.
