Rough Country 3/4 level kit
joesrepsol
Joe
Rocklin, CA
2022 Ford Lightning Lariat
Solutions Engineer
No. I went Ready Lift. Honestly, heard nothing but (-) comments from installers/shops about RC suspension products. Not talking smack, just repeated was I was told by 3 different local shops? So I went Ready Lift. Super happy with 2" level spacers.
uniblab
Dallas, Tx.
'22 Lightning XLT SR , '93 Mustang GT, '11 E450
Just had the 52006 kit installed today, but only the rear portion as I did not want to raise the front at all. Measured a 1.25" drop in the rear which was noticeable but I wish it was double that. No change in ride quality although I would expect the truck to bottom out more easily with heavy loads. The biggest issue is that it has rendered my onboard scales just about useless - the truck thinks it's carrying an extra ~1,200lb load around now. Does anyone happen to know where the onboard scale sensors are located? I need to figure out how to reset the scale (the built-in reset does not fix this). Thanks!
nate002
nate
‘24 Flash | Antimatter Blue | 9.6kW Pro Power
I just installed the kit today, but chose to only install the rear drop platforms and didn’t add the 3/4” spacers to the front. Overall a relatively painless way to lessen the dorky looking rake.
nate002
nate
Thank you for the pics of the rear only drop for the Rough Country leveling kit! I am looking to do this as well, but I’m wondering if they only sell the rear portion and perhaps increase the drop to 2 inches? Or is there any way to increase the drop another inch or so easily while installing the 1.25in drop kit?
RickKeen
Rick
F150L SR Pro
sw engineering manager,
The sensor is a potentiometer with an apx 2" lever and linkage mounted to the frame just near the front pivot of the cast aluminum trailing arm. It measures how far the suspension is compressed.
To get the zero point reset, you are going to need to shorten the linkage or rotate the sensor so its at its zero position when the truck is empty. Not sure if its easily adjustable that far.
It has to presume a given spring rate of the rear suspension, so if you changed the spring rate and not just the offfset it will need to be recalibrated for the spring rate as well. Not sure if that is something possible in Forscan.
Ford F-150 Lightning Rough Country 3/4 level kit 1736895189634-1d
KHines
Kevin
Delaware
Hey Nate
When I was installing, and researching for that matter, it seemed like going more than 1.25inches was getting mighty close to the bump stops. I wanted more rear drop myself, but was not interested in killing ride quality.
I’ll take a look at my rear suspension as it sits unladen and see how much more travel there is, for information’s sake.
-Kev
nate002
nate
Awesome, thanks guys!
KHines
Kevin
Delaware
Totally forgot that I checked last night
With the 1.25 drop there is about two inches of travel before the bump stops.
nate002
nate
Thanks Kyle. Have you noticed any difference in ride quality, specifically on rough or bumpy sections of road, or off road?If so, would you recommend just doing the 2 inch leveling in the front now having experience with the 1.25 drop in the rear?
KHines
Kevin
Delaware
There is no change in ride quality because the spring and damping rates are not changed. Raising the front does not appeal to me so I didn’t even consider it. I will say bed access is much easier with this rear drop.
nate002
nate
Good deal, I think I’ll just go with the 1.25 in the back then. Thank you for all the feedback!
Tractionlimit
Ryan
2024 F150 Lightning Flash
Can you explain more about this measurement? Does this mean you will hit the bump stops sooner, either under load, or with potholes, etc?
I like the look and idea of easier access for sure, but 2" doesn't seem like much travel at all. Or am I understanding wrong?
JRT
Huntsville, AL
Lightning
Anyone install the front? I like the lower look, but if it can't be level, I think adding the 3/4 to the front will be a better level look.
