#2 copper wire for Charge Station Pro
FOXTAIL
Ron
Ocala, Florida
2023 Ford Lightning
Will #2 copper wire fit in the Charge station pro? My charger is due to arrive on Monday 5/6/2024. I have a line on the #2 for a good price.
Zaptor
2022 Lightning Lariat ER ZAPTOR 2025 MME GT RALLY HABOOB Kubota L3560 Goats wut
.......... Trophy husband
According to the bill for my install, yes, though I didn't put eyes on the terminals inside the unit.
It's fantastic at that charging rate BTW, and you will not be disappointed!
Cheers
-Zap
FOXTAIL
Ron
Ocala, Florida
2023 Ford Lightning
Thanks for your input.
dww
San Antonio, TX
F150L, Tesla 3P, YP
I used #2 and it fit. For some reason you need a minimum of 8ft (I think that is what it speced) though.
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
Same. lowes didnt have 3awg so i got 2awg. works great. fit no problem
I don’t believe any minimum length is specified.
dww
San Antonio, TX
F150L, Tesla 3P, YP
I was about to go insane trying to find this because I could not find my install manual and had to search a pdf. It’s in a diagram, not a written note.
Ford F-150 Lightning #2 copper wire for Charge Station Pro IMG_4951
Danface
Dan
Central Mass
2023 Lightning XLT
You can use 100 amp copper service wire, it's cheaper then THHN ( I found that out after ordering everything).
How long a run do you have?
mrau
23 Lariat⚡ER
Maybe the "Minimum 8 FT" refers to how far the safety switch (if needed) should be from the Charge Station Pro.
Ford F-150 Lightning #2 copper wire for Charge Station Pro Screenshot 2024-05-06 at 11.10.18 AM
Wow, that’s bizarre. As an electrical engineer, I can’t come up with a reason for that. I have about 18” of wire between my disconnect and the FCSP.
ETA - that diagram isn’t in my manual nor did it come with my unit. I wonder what its origin is?
Kniaz
Ivan
CA
F-150 lightning lariat ER CarboneGray
work
Ford F-150 Lightning #2 copper wire for Charge Station Pro 20231028_205527
Ford F-150 Lightning #2 copper wire for Charge Station Pro 20231029_151431
Reactions: dww
dww
San Antonio, TX
F150L, Tesla 3P, YP
Maybe the "
Yeah, I don’t know why either. The “disconnect distance” comment above makes some sense, but 8 ft? It was in my manual but this is where I took the screen shot.
https://chargers.ford.com/gcs/B2C/chargers/InstallationGuide/NLNL38-10C823-AC.pdf
I noticed the Ford part number on that manual ends in “AC”. Mine is “AB”.
If I was going specify a spacing between equipment, I wouldn’t use the word “length.”
