Check your charge ports before plugging in. What's the worst you've seen?
SpaceEVDriver
Arizona
I need to get into the habit of checking my charge ports and the charge plugs before plugging in.
I unplugged the FCSP from the Lightning yesterday and noticed this. Gotta watch for bugs.
Ford F-150 Lightning Check your charge ports before plugging in. What's the worst you've seen? PXL_20240517_220114118
A few weeks ago, I happened to check a NACS plug before plugging it into my A2ZEV charge adapter and the Mustang, and I noticed that it was missing a pin. Gotta watch for damage.
Ford F-150 Lightning Check your charge ports before plugging in. What's the worst you've seen? PXL_20240503_172905892 (1)
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
Yup, grabbed my Charfe plug from my Charge Station Pro a few weeks back and discovered ants had made a wonderful nest under its cover and in the plug... Enjoyed the challenge of spraying ant repellant around the plug aninside the Charge Station Pro :crazy:
I never use Charfe plugs due to their attractiveness to ants.
SpaceEVDriver
SpaceEVDriver
Arizona
You do you. Charging might still have happened, but though a much reduced surface area, which means higher resistance and greater heating. I'll stick to unbroken pins.
Ekiehn
Eric
Ahh.. where was spell check when you need it... at least I know charfe...ugh now spell check works... is a word or maybe not :)
SpaceEVDriver
SpaceEVDriver
Arizona
That is a supercharger NACS plug.
