FORD: Please add lock status to FordPass app main screen
2wheeltraveler
Austin, TX
2022 F150 Lightning Lariat Rapid Red
I never ask myself "is my vehicle parked", however I ALWAYS wonder if my vehicle is locked. This would be a great location to add that key piece of data in addition to, or a replacement for parked status.
The locked status is in the HomeAssistant integration so the data appears to be avail
@Ford Motor Company
Ford F-150 Lightning FORD: Please add lock status to FordPass app main screen IMG_4747
Lytning
Georgia
If @Ford Motor Company can't give us 12 volt battery SOC, maybe they could change the Ready light to indicate "Ready for OTA update". It would almost always be off. ?
davehu
hot springs, AR
@Ford Motor Company
so just click the lock button and your done. the time is takes is the same because if you just want to know IF it's locked Ford Pass has to connect with the truck to find out. so just lock it. same difference.
2wheeltraveler
2wheeltraveler
Austin, TX
We’ll have to agree o disagree on that one, a quick check to see if it’s locked vs sending an unnecessary lock command is not the same. It’s also different if you are able to realize that your car has been unlocked for a period of time which could be important in various situations.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Has anyone verified if the truck can tell if it is locked? I haven’t seen a lock status anywhere in Car Scanner so I’m not sure if the door modules report the status.
2wheeltraveler
2wheeltraveler
Austin, TX
If you run a home automation solution like HomeAssistant, you can see those items in the dump from Ford Pass so it’s definitely there.
Means it's ready to drive - you pressed the brake pedal while pressing start. Press start without the brake pedal and you will not be ready or able to drive (you're in Accessory mode).
Ford F-150 Lightning FORD: Please add lock status to FordPass app main screen 1724893145910-n5
MountainAlive
Massachusetts, USA
I would extend this request to app alerts as well. For example, on my Toyota Highlander if I park and leave it unlocked, leave a window open, leave the hatch open, sunroof etc I will get an alert about 5 mins after parking saying “passenger rear window open” or “rear hatch is still open” etc.
Albern
Second star to the right
On the UI you can do this by having a single lock/unlock button.
Also, am interrupted charge session notification would be nice.
The decisions Ford made with FordPass are so strange.
